Inleiding
This guide will be helpful in the case that your device will not charge or has been dislodged. In this guide you will be using a #1 and #1.5 screwdriver, to remove screws and components. Once you have access to the motherboard, locate and use soldering techniques to remove USB connector.
Onderdelen
Geen onderdelen opgegeven.
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
Identify the USB connector. Remove and replace the component with a functioning USB device. Refer to the link below for soldering techniques. Hoe moet je (de-)solderen?
3 Opmerkingen
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Where can I purchase the usb
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
