Ga door naar hoofdinhoud
Inleiding
This guide will be helpful in the case that your device will not charge or has been dislodged. In this guide you will be using a #1 and #1.5 screwdriver, to remove screws and components. Once you have access to the motherboard, locate and use soldering techniques to remove USB connector.
  1. Photive Hydra USB Connector Replacement, Face Plate and Back Plate: stap 1, afbeelding 1 van 1
    • Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
  2. Photive Hydra USB Connector Replacement: stap 2, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 2, afbeelding 2 van 2
    • Use a plastic opening tool to pry off the face plate.
  3. Photive Hydra USB Connector Replacement: stap 3, afbeelding 1 van 1
    • Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
  4. Photive Hydra USB Connector Replacement: stap 4, afbeelding 1 van 1
    • Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
  5. Photive Hydra USB Connector Replacement: stap 5, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 5, afbeelding 2 van 2
    • Use plastic opening tool to pry off back plate.
    • Move the plastic opening tool along the the device to further pry open the device.
    • Be careful when taking this plate off. You may accidentally damage the water proof seal.
  6. Photive Hydra USB Connector Replacement, Battery (Prerequisite): stap 6, afbeelding 1 van 2 Photive Hydra USB Connector Replacement, Battery (Prerequisite): stap 6, afbeelding 2 van 2
    • Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
  7. Photive Hydra USB Connector Replacement: stap 7, afbeelding 1 van 1
    • Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
  8. Photive Hydra USB Connector Replacement, USB Connector: stap 8, afbeelding 1 van 2 Photive Hydra USB Connector Replacement, USB Connector: stap 8, afbeelding 2 van 2
    • Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
  9. Photive Hydra USB Connector Replacement: stap 9, afbeelding 1 van 2 Photive Hydra USB Connector Replacement: stap 9, afbeelding 2 van 2
    • Pull the motherboard up and out to remove.
  10. Photive Hydra USB Connector Replacement: stap 10, afbeelding 1 van 1
    • Identify the USB connector. Remove and replace the component with a functioning USB device. Refer to the link below for soldering techniques. Hoe moet je (de-)solderen?
Conclusie
Jose Muzaurieta
111 Reputatie
1 Handleiding geschreven
USF Tampa, Team 11-3, Cheng Spring 2016 Lid van USF Tampa, Team 11-3, Cheng Spring 2016
USFT-CHENG-S16S11G3
5 Leden
6 handleidingen geschreven
3 Opmerkingen
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Abraham Hernandez - Antwoord
Where can I purchase the usb
Sonia Lance - Antwoord
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 631
