Ga door naar hoofdinhoud
Philips Sonicare DiamondClean Circuit Board Replacement
Wat je nodig hebt
  1. Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: stap 1, afbeelding 1 van 2 Philips Sonicare DiamondClean Circuit Board Replacement, Circuit Board: stap 1, afbeelding 2 van 2
    • Pull the brush head from the toothbrush.
  2. Philips Sonicare DiamondClean Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Use a spudger to pry the chrome cap from the base of the toothbrush.
  3. Philips Sonicare DiamondClean Circuit Board Replacement: stap 3, afbeelding 1 van 3 Philips Sonicare DiamondClean Circuit Board Replacement: stap 3, afbeelding 2 van 3 Philips Sonicare DiamondClean Circuit Board Replacement: stap 3, afbeelding 3 van 3
    • Invert the toothbrush and apply pressure against the metal tip until the internals and casing separate.
    • Remove the internals from the casing.
  4. Philips Sonicare DiamondClean Circuit Board Replacement: stap 4, afbeelding 1 van 1
    • Remove the rubber covers from the circuit board and battery.
  5. Philips Sonicare DiamondClean Circuit Board Replacement: stap 5, afbeelding 1 van 1
    • Carefully free the top end of the circuit board from the plastic clips holding it in place.
  6. Philips Sonicare DiamondClean Circuit Board Replacement: stap 6, afbeelding 1 van 1
    • Use the soldering iron to desolder the terminals marked F1, C5, R7, R6, and JP1.
    • Check out our How to Solder and Desolder Connections guide for help with soldering best practices!
    • Remove the circuit board.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 64
Altijd: 2,748
