Ga door naar hoofdinhoud
Philips SBA1060 Circuit Board Replacement
Wat je nodig hebt
  1. Philips SBA1060 Circuit Board Replacement, Battery Casing: stap 1, afbeelding 1 van 1
    • Remove the back cover by sliding it off.
    • Remove the 3 AAA batteries.
  2. Philips SBA1060 Circuit Board Replacement: stap 2, afbeelding 1 van 3 Philips SBA1060 Circuit Board Replacement: stap 2, afbeelding 2 van 3 Philips SBA1060 Circuit Board Replacement: stap 2, afbeelding 3 van 3
    • Unscrew the nine exterior screws on the back panel using a PH0-size Philips-head screwdriver.
    • A larger screwdriver head and more force may be required for damaged screws.
    • Remove the triangular end piece by pulling it straight off.
  3. Philips SBA1060 Circuit Board Replacement: stap 3, afbeelding 1 van 2 Philips SBA1060 Circuit Board Replacement: stap 3, afbeelding 2 van 2
    • Remove the colored grill by sliding it off in the direction of the removed end piece.
    • Pry off the back battery panel with the plastic opening tool.
    • Be careful to avoid tearing any wires.
  4. Philips SBA1060 Circuit Board Replacement, Circuit Board: stap 4, afbeelding 1 van 1
    • Remove the two screws on opposite ends of the circuit board with the PH0 size philips head screw driver.
    • Remove the damaged circuit board from the device.
  5. Philips SBA1060 Circuit Board Replacement: stap 5, afbeelding 1 van 2 Philips SBA1060 Circuit Board Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery plug from the circuit board by pulling out the plugs to fully remove back panel.
    • Remove the speaker plugs from the circuit board by pulling out the plugs. They are located on opposite sides of the circuit board.
    • NOTE: When reassembling, note that the speaker with the red wire goes to the red plug, and the speaker with the white wire goes to the adjacent white plug.
    • Remove the light plug from the circuit board.
    • NOTE: This plug is twice as wide as the speaker and battery plugs.
    • Reassemble the device.
Conclusie
April Driscoll
321 Reputatie
3 handleidingen geschreven
Clemson, Team 14-4, Benson Fall 2013 Lid van Clemson, Team 14-4, Benson Fall 2013
CLEM-BENSON-F13S14G4
3 Leden
4 handleidingen geschreven
2 opmerkingen
Is that one of those cheap pam amps that run from 5v?
fabio souza jr - Antwoord
Nice picture,it helps a lot in trouble shooting !
sergio - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 12
Altijd: 1,311
