Ga door naar hoofdinhoud
Philips Respironics V60 Touchscreen Replacement
Medische apparatuur
Noch iFixit, noch deze reparatiehandleiding worden onderschreven door of zijn gelieerd aan de fabrikant van de desbetreffende medische apparatuur.
    1. Philips Respironics V60 Touchscreen Replacement, Touchscreen: stap 1, afbeelding 1 van 1
      • From the Diagnostics Menu, select Touch Screen Calibration. The Calibrate Touch Screen screen is displayed.
      • Follow the steps shown. Press on the middle of each target with a blunt, narrow object.
      • NOTE: If the Touch Screen Calibration button does not respond, press the Accept button on the navigation ring to begin
      • If the calibration is not successful, have the ventilator serviced.
      Vraag FixBot
      Voeg opmerking toe
    2. Philips Respironics V60 Touchscreen Replacement: stap 2, afbeelding 1 van 1
      • Press and release the ON/Shutdown key, opening the Shutdown window in the screen.
      • Select Ventilator Shutdown, which will shut down the ventilator.
      • Improper shutdown may cause a Power has been restored message the next time the ventilator is turned on.
      Vraag FixBot
      Voeg opmerking toe
    3. Philips Respironics V60 Touchscreen Replacement: stap 3, afbeelding 1 van 1
      • Remove the screws from the end cap and remove the end cap.
      • Remove the screws from the rear bezel.
      • Separate the front and rear bezel.
      Vraag FixBot
      Voeg opmerking toe
    4. Philips Respironics V60 Touchscreen Replacement: stap 4, afbeelding 1 van 1
      • Disconnect these cables from the UI PCBA: • Switch PCBA cable • Nav-ring cable • Power switch overlay cable • Touch screen cable
      • Remove the switch PCBA.
      • Remove the screw that attaches the cable clamp to the LCD tray.
      • Remove the screws and washers that attach the LCD tray to the front bezel, then remove the LCD tray.
      • Remove the touch screen from the front bezel.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Weihan Du
241 Reputatie
2 handleidingen geschreven
Cal Poly, Team S7-G10, Paton Spring 2020 Lid van Cal Poly, Team S7-G10, Paton Spring 2020
CPSU-PATON-S20S7G10
2 Leden
53 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 38
Altijd: 2,826
