Ga door naar hoofdinhoud
Philips HD9252 Touch Screen Motherboard Replacement
Wat je nodig hebt
  1. Philips HD9252 Touch Screen Motherboard Replacement, Top: stap 1, afbeelding 1 van 1
    • Insert a nylon spudger underneath the top of the device.
    • Leverage the tool and pop off each of the eight tabs holding the plastic cover in place.
  2. Philips HD9252 Touch Screen Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Remove the four 12.4 mm screws in each of the corners using a JIS #1 screwdriver.
  3. Philips HD9252 Touch Screen Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the top by lifting it upwards and setting it down.
    Hi, I cannot lift the top half because it's blocked by the exhaust vent. Any step that I am missing?
    Lorenzo Giraudi - Antwoord
  4. Philips HD9252 Touch Screen Motherboard Replacement, Touch Screen Motherboard: stap 4, afbeelding 1 van 2 Philips HD9252 Touch Screen Motherboard Replacement, Touch Screen Motherboard: stap 4, afbeelding 2 van 2
    • Remove the back panel from the touch screen motherboard by popping the tabs off using the nylon spudger.
  5. Philips HD9252 Touch Screen Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the touch screen motherboard.
Conclusie
Zach Person
463 Reputatie
4 handleidingen geschreven
1Gids Commentaar
Does the same method apply to milex airfryer 5.6 litre xxxl ? Coz when I switch it on it does not respond
Morena - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 72
Altijd: 448
