Inleiding
This guide will walk you through removing the old power supply for the DVD player so that a new one may be installed. This guide will also show you how to replace a blown fuse if needed.
Wat je nodig hebt
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Slide the power cord out from the case.
Be sure not to lose the rubber clip that is wrapped around the cord.
7 andere personen hebben deze handleiding voltooid.
