Inleiding
In this guide, we are going to detach the disc tray from the device.
Wat je nodig hebt
Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
Remove five 7.5 mm Phillips screws on the back of the player.
Remove two 7.5 mm screws, one on each side of the player.
Remove three 7.5mm screws from the bottom of the player.
6 andere personen hebben deze handleiding voltooid.
3Gids Commentaar
If you work at it, inserting a small screwdriver at appropriate places, you can get the drawer front off (do this with drawer open). This is easier than removing the front panel from the player.
I failed huhuhu
