Ga door naar hoofdinhoud
Philips DS3000 Speakers Replacement
Wat je nodig hebt
  1. Philips DS3000 Speakers Replacement, Speakers: stap 1, afbeelding 1 van 1
    • Pry off the front fascia by inserting a plastic opening tool between the fascia and white casing.
  2. Philips DS3000 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Pull the ZIF (zero insertion force) white ribbon out of the circuit board by hand located on the back of the front fascia. Be careful when pulling it out of the connector.
  3. Philips DS3000 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Remove the 10 screws from the black internal housing (6 black screws, 4 silver screws). They are all phillips #1 screws and the black screws are 10 mm in length and the silver screws are 8 mm in length.
  4. Philips DS3000 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Slowly pry around the black housing with the plastic opening tool to remove it from the back housing.
  5. Philips DS3000 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Remove the 4 phillips #1 head silver screws from the green circuit board. They are located on the four corners of the board and are 8 mm in length.
  6. Philips DS3000 Speakers Replacement: stap 6, afbeelding 1 van 1
    • Remove the black tube (speaker port) by unscrewing the silver phillips head #1 screw (8 mm in length) that connects it to the black housing. Pull it off from where it wraps around the black housing's mating port.
  7. Philips DS3000 Speakers Replacement: stap 7, afbeelding 1 van 1
    • Remove the 4 silver phillips head #1 screws from the back of the speaker that are 7 mm in length.
  8. Philips DS3000 Speakers Replacement: stap 8, afbeelding 1 van 1
    • Remove the speaker from the black housing.
  9. Philips DS3000 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Remove about an inch of the black sponge insulation from around the red (positive) and black (negative) speaker wires.
  10. Philips DS3000 Speakers Replacement: stap 10, afbeelding 1 van 2 Philips DS3000 Speakers Replacement: stap 10, afbeelding 2 van 2
    • Use the soldering iron to heat up the terminal spots on the speaker and remove each wire (red and black).
  11. Philips DS3000 Speakers Replacement: stap 11, afbeelding 1 van 1
    • Strip about a quarter inch of the rubber insulation away from each of the speaker wires (red and black wires) using the 6 inch wire strippers.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew McAuliffe
128 Reputatie
1 Handleiding geschreven
Michigan Tech, Team 5-7, Lauer Spring 2014 Lid van Michigan Tech, Team 5-7, Lauer Spring 2014
MTU-LAUER-S14S5G7
3 Leden
2 handleidingen geschreven
Één opmerking
i hardly difficult to treat 2 defective speakers. i find the flat cable a little loose on the main plate. thank you!!!
araujojraa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 19
Altijd: 3,427
