Ga door naar hoofdinhoud
Petnet SmartFeeder SF10E 12 Pin Connector Replacement
Wat je nodig hebt
    1. Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement, 12 Pin Connector: stap 1, afbeelding 3 van 3
      • Eject the SmartBowl by pressing the button located at the front of the SmartFeeder base.
      Vraag FixBot
      Voeg opmerking toe
    2. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 2, afbeelding 3 van 3
      • Remove the food tub by twisting it counter-clockwise with both hands and lifting it up.
      Vraag FixBot
      Voeg opmerking toe
    3. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 3, afbeelding 1 van 1
      • Remove the black plastic gasket from the top of the SmartFeeder by placing your fingers on the side of it and lifting up.
      • It should come off easily.
      Vraag FixBot
      Voeg opmerking toe
    4. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 4, afbeelding 1 van 1
      • Flip over the SmartFeeder by using both hands.
      • Partially open the outer case of the SmartFeeder by wedging an iFixit Opening Tool on each side.
      Vraag FixBot
      Voeg opmerking toe
    5. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 5, afbeelding 1 van 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 5, afbeelding 2 van 2
      • Turn the SmartFeeder on its side and with one hand on the base, carefully pull out the central section.
      • Place the bottom piece of the device right-side up.
      Vraag FixBot
      Voeg opmerking toe
    6. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 6, afbeelding 1 van 2 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 6, afbeelding 2 van 2
      • Remove one 10 mm screw by using the Phillips #1 screwdriver.
      • Remove the plastic retaining piece for the daughterboard by pulling it out with one hand.
      Vraag FixBot
      Voeg opmerking toe
    7. Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 1 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 2 van 3 Petnet SmartFeeder SF10E 12 Pin Connector Replacement: stap 7, afbeelding 3 van 3
      • Pull the daughterboard out of the device and remove the three-prong connectors by using your hands.
      • Hold onto the sockets on the motherboard or you could accidentally pull off the entire assembly.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ashley Kim
187 Reputatie
1 Handleiding geschreven
Cal Poly, Team S13-G7, White Fall 2018 Lid van Cal Poly, Team S13-G7, White Fall 2018
CPSU-WHITE-F18S13G7
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 617
