Ga door naar hoofdinhoud
Pentax Super Program Front Block Functional Check
    1. Pentax Super Program Front Block Functional Check, Prepare the front block: stap 1, afbeelding 1 van 3 Pentax Super Program Front Block Functional Check, Prepare the front block: stap 1, afbeelding 2 van 3 Pentax Super Program Front Block Functional Check, Prepare the front block: stap 1, afbeelding 3 van 3
      • Connect a lead wire to the main flex PCB to supply battery power (early production).
      • Connect a lead wire to the main flex PCB to supply battery power (late production).
      • Make a ground connection to the body of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Pentax Super Program Front Block Functional Check, Prepare the mode dial: stap 2, afbeelding 1 van 2 Pentax Super Program Front Block Functional Check, Prepare the mode dial: stap 2, afbeelding 2 van 2
      • Ground the mode dial plate to the chassis of the front block.
      • Move the mode dial to the 'M' position.
      • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
      Vraag FixBot
      Voeg opmerking toe
    3. Pentax Super Program Front Block Functional Check, Check power to the front block: stap 3, afbeelding 1 van 2 Pentax Super Program Front Block Functional Check, Check power to the front block: stap 3, afbeelding 2 van 2
      • Use a source of 2.8 V to power the front block, the lowest battery voltage that the camera should operate at.
      • If an external power supply is not available, use fresh batteries to supply power.
      • Check the voltage at these locations to make sure that power is getting to all of the components.
      Vraag FixBot
      Voeg opmerking toe
    4. Pentax Super Program Front Block Functional Check, Check the main shutter release: stap 4, afbeelding 1 van 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: stap 4, afbeelding 2 van 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: stap 4, afbeelding 3 van 3
      • Charge the mirror mechanism.
      • Press the shutter button. The mirror should release and flip up into the taking position.
      • Push the mirror return latch to flip the mirror down into the viewing position (the shutter would trigger this mechanism when the camera is fully assembled).
      Vraag FixBot
      Voeg opmerking toe
    5. Pentax Super Program Front Block Functional Check, Check the self-timer: stap 5, afbeelding 1 van 2 Pentax Super Program Front Block Functional Check, Check the self-timer: stap 5, afbeelding 2 van 2
      • Pull out the tab on the self-timer switch.
      • Press the shutter release button.
      • The self-timer led should blink and the buzzer should sound.
      • After ten seconds, the mirror should flip up.
      Vraag FixBot
      Voeg opmerking toe
    6. Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: stap 6, afbeelding 1 van 2 Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: stap 6, afbeelding 2 van 2
      • Ground this pad to release the shutter (early production).
      • Ground this pad to release the shutter (late production).
      • This is the signal that the accessory motor drive uses to fire the shutter. It's also a useful alternative if you think there is an issue with the main shutter release.
      Vraag FixBot
      Voeg opmerking toe
      • Mount a lens on the front block. Set the aperture ring to 'A'.
      • Point the front block at scenes with varying brightness. Check that the aperture value in the viewfinder display changes accordingly.
      Vraag FixBot
      Voeg opmerking toe
    7. Pentax Super Program Front Block Functional Check, Check viewfinder backlight: stap 8, afbeelding 1 van 2 Pentax Super Program Front Block Functional Check, Check viewfinder backlight: stap 8, afbeelding 2 van 2
      • Cover the ambient light panel for the viewfinder displays.
      • Press viewfinder light button on the side of the lens mount.
      • The displays at the bottom of the viewfinder should light up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Sam Gustafson
14.444 Reputatie
78 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 27
Altijd: 146
