Inleiding
Use this guide to receive step-by-step help with removing and replacing the motherboard
Wat je nodig hebt
Orient the camera so you are looking at the bottom and the battery compartment is on the right hand side.
Unlock the battery compartment by sliding the lock switch to the unlock position (away from the arrow).
Firmly push the battery cover to the right and swing open.
The battery will be located in the larger bottom slot. Slide the plastic orange tab to remove the battery.
The SD card will be located in the smaller, top slot. Push the SD card directly in to hear a small clicking sound. Then pull out the SD card.
With the battery cover swung open, use the spudger to remove the DC IN sticker.
Remove the 4.3 mm silver screw revealed.
Reorient the camera so it is upright and you are looking at the back screen.
Remove the rubber covers in the upper and lower right side corners. Insert spudger in between the camera case and the rubber cover and push them out of their sockets. Grab the rubbers with the tweezers and set them aside. Remove both of the 4.3 mm silver screws revealed.
Remove the 4.3 mm silver screw in the lower left corner which resides under the sliding battery cover.
Orient the camera so you are looking at the LCD screen.
Using the forceps, remove the red and white wires out of the terminal in the bottom left corner.
Carefully pry the electronic internals out of the front casing with the spudger.
With tweezers, carefully detach the ribbon on the upper right corner of the internals that is connected to the shutter release/power button.
Remove the 4 mm black screw on the bottom right corner of the mother board.
Use the spudger to open the black flip gate revealed under the motherboard. This gate attaches the copper ribbon to the motherboard.
