Ga door naar hoofdinhoud
Pentax MX Front Board Removal
Wat je nodig hebt
  1. Pentax MX Front Board Removal, Remove film advance lever: stap 1, afbeelding 1 van 3 Pentax MX Front Board Removal, Remove film advance lever: stap 1, afbeelding 2 van 3 Pentax MX Front Board Removal, Remove film advance lever: stap 1, afbeelding 3 van 3
    • Remove the lever cap. The cap is reverse threaded.
    • Lift off the advance lever.
    • Remove the collar beneath the lever.
    Vraag FixBot
    Voeg opmerking toe
  2. Pentax MX Front Board Removal, Remove shutter speed dial: stap 2, afbeelding 1 van 2 Pentax MX Front Board Removal, Remove shutter speed dial: stap 2, afbeelding 2 van 2
    • Set the ISO to 100 and the shutter speed to 1000.
    • Remove one pin head screw.
    • Lift off shutter speed dial.
    • Remove the collar beneath the dial.
    • Installation Notes: Make sure that the tab on the shutter speed resistor mates properly with this slot on the shutter speed dial.
    Vraag FixBot
    Voeg opmerking toe
  3. Pentax MX Front Board Removal, Remove rewind knob: stap 3, afbeelding 1 van 3 Pentax MX Front Board Removal, Remove rewind knob: stap 3, afbeelding 2 van 3 Pentax MX Front Board Removal, Remove rewind knob: stap 3, afbeelding 3 van 3
    • Place a tool in the fork of the rewind shaft. Turn the rewind knob counterclockwise to loosen it.
    • Remove the lock ring underneath the rewind knob.
    • Remove the cover plate.
    Vraag FixBot
    Voeg opmerking toe
  4. Pentax MX Front Board Removal, Remove top cover: stap 4, afbeelding 1 van 3 Pentax MX Front Board Removal, Remove top cover: stap 4, afbeelding 2 van 3 Pentax MX Front Board Removal, Remove top cover: stap 4, afbeelding 3 van 3
    • Remove two M1.7 x 3.2 mm screws.
    • Remove two M1.7 x 2 mm countersunk screws.
    • Lift off top cover.
    • The release cable pin in the shutter button is loose and may fall out.
    Vraag FixBot
    Voeg opmerking toe
  5. Pentax MX Front Board Removal, Remove front leatherette panels: stap 5, afbeelding 1 van 3 Pentax MX Front Board Removal, Remove front leatherette panels: stap 5, afbeelding 2 van 3 Pentax MX Front Board Removal, Remove front leatherette panels: stap 5, afbeelding 3 van 3
    • Apply isopropyl alcohol to soften the leatherette adhesive.
    • Turn the self-timer lever to the charged position.
    • Peel the leatherette off the camera body, carefully working it over the self-timer lever.
    • Remove one loose cover panel.
    • Repeat for the opposite panel.
    • Installation Notes: Clean all the old adhesive off of the camera body and leatherette panels before reapplying. Use contact cement to attach.
    Vraag FixBot
    Voeg opmerking toe
  6. Pentax MX Front Board Removal, Unsolder aperture resistor: stap 6, afbeelding 1 van 1
    • Unsolder two yellow wires for the aperture resistor.
    Vraag FixBot
    Voeg opmerking toe
  7. Pentax MX Front Board Removal, Remove front board: stap 7, afbeelding 1 van 3 Pentax MX Front Board Removal, Remove front board: stap 7, afbeelding 2 van 3 Pentax MX Front Board Removal, Remove front board: stap 7, afbeelding 3 van 3
    • Remove four M1.9 x 3.9 mm screws.
    • Lift off front board.
    • Look for shim washers at the screw locations and note their positions.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sam Gustafson
14.384 Reputatie
78 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 44
Altijd: 120
