Ga door naar hoofdinhoud
Pentax ME Super Mirror Box Service
Wat je nodig hebt
    1. Pentax ME Super Mirror Box Service, Remove wind lever: stap 1, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove wind lever: stap 1, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove wind lever: stap 1, afbeelding 3 van 3
      • Wrap a piece of masking tape around your thumb, sticky side out.
      • Turn the wind lever cap clockwise to remove (it is reverse threaded).
      • Remove the wind lever lock ring (it is also reverse threaded).
      • Remove the brass spring washer.
      • A pair of fine tipped pliers or nippers can be used in place of a spanner wrench. Be careful!
      Vraag FixBot
      Voeg opmerking toe
    2. Pentax ME Super Mirror Box Service, Remove rewind lever: stap 2, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove rewind lever: stap 2, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove rewind lever: stap 2, afbeelding 3 van 3
      • Place a tool in the fork of the rewind spindle.
      • Unscrew the rewind lever.
      • Remove the lock ring with a spanner.
      • Lift off the ISO/Exposure Compensation dial.
      Vraag FixBot
      Voeg opmerking toe
    3. Pentax ME Super Mirror Box Service, Installation Notes: ISO dial: stap 3, afbeelding 1 van 1
      • Ensure that the ISO dial couples with the tab on the resistor.
      • Turn the Exposure Compensation to 1/4x then back to 4x while gently pushing down. This will help the dial engage with the detent mechanism properly.
      Vraag FixBot
      Voeg opmerking toe
    4. Pentax ME Super Mirror Box Service, Unscrew top cover: stap 4, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Unscrew top cover: stap 4, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Unscrew top cover: stap 4, afbeelding 3 van 3
      • Remove two 3.3 mm #00 screws.
      • Remove one 3.2 mm #00 screw.
      • Remove one 2.6 mm #00 screw.
      Vraag FixBot
      Voeg opmerking toe
    5. Pentax ME Super Mirror Box Service, Unscrew top cover: stap 5, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Unscrew top cover: stap 5, afbeelding 2 van 2
      • Remove two 4.3 mm #00 screws.
      Vraag FixBot
      Voeg opmerking toe
    6. Pentax ME Super Mirror Box Service: stap 6, afbeelding 1 van 2 Pentax ME Super Mirror Box Service: stap 6, afbeelding 2 van 2
      • Lift off the top cover. The silver trim piece is loose and may fall away.
      • Remove loose washer.
      Vraag FixBot
      Voeg opmerking toe
    7. Pentax ME Super Mirror Box Service, Installation Notes: Top Cover: stap 7, afbeelding 1 van 1
      • The shutter pin is loose. Make sure it is in place before installing the top cover.
      • The mode dial pin must be properly coupled with the mechanisms in the camera for it to work.
      • Set the mode dial to 'M'. Place the top cover on the camera. Move the mode dial to 'B' then back to 'M' while gently pushing down.
      • The mode dial should click into place and work properly.
      Vraag FixBot
      Voeg opmerking toe
    1. Pentax ME Super Mirror Box Service, Remove self-timer lever: stap 8, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove self-timer lever: stap 8, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove self-timer lever: stap 8, afbeelding 3 van 3
      • Use a spanner or tweezers to remove remove self-timer screw. It is reverse threaded.
      • Remove self-timer lever.
      • Remove black spacer.
      • Remove spring washer.
      Vraag FixBot
      Voeg opmerking toe
    2. Pentax ME Super Mirror Box Service, Remove bottom cover: stap 9, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Remove bottom cover: stap 9, afbeelding 2 van 2
      • Remove two 3.0 mm #00 screws.
      • Remove one 2.1 mm #00 screw.
      • Remove loose plastic cover for motor drive pins.
      Vraag FixBot
      Voeg opmerking toe
    3. Pentax ME Super Mirror Box Service, Remove ISO resistor: stap 10, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove ISO resistor: stap 10, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove ISO resistor: stap 10, afbeelding 3 van 3
      • Unsolder two yellow wires.
      • Remove one 3.0 mm #00 screw.
      • Remove one 5.9 mm flat head screw.
      • Lift off ISO resistor.
      Vraag FixBot
      Voeg opmerking toe
    4. Pentax ME Super Mirror Box Service, Unsolder left side connections: stap 11, afbeelding 1 van 1
      • Unsolder one red wire (positive battery).
      • Unsolder one pink wire.
      • Unsolder one purple wire.
      Vraag FixBot
      Voeg opmerking toe
    5. Pentax ME Super Mirror Box Service, Unsolder right side connections: stap 12, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Unsolder right side connections: stap 12, afbeelding 2 van 2
      • Unsolder the red and blue wires (positive battery). They may share a pad.
      • Unsolder one gray wire.
      • Unsolder one white wire.
      • Unsolder one brown wire.
      • Unsolder one metal contact.
      • The wiring in this area varies with ME Supers from different production years. You may need to document the wiring for your own camera separately.
      Vraag FixBot
      Voeg opmerking toe
    6. Pentax ME Super Mirror Box Service, Unsolder motor winder connections: stap 13, afbeelding 1 van 1
      • Unsolder one green wire.
      • Unsolder one blue wire.
      • Unsolder one red wire.
      • On some cameras the wiring order may be green/red/blue.
      Vraag FixBot
      Voeg opmerking toe
    7. Pentax ME Super Mirror Box Service, Remove front leatherette: stap 14, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove front leatherette: stap 14, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove front leatherette: stap 14, afbeelding 3 van 3
      • Apply isopropyl alcohol to soften the leatherette adhesive.
      • Use a dull scraper to left the edge of the covering.
      • Peel the leatherette away and remove it from both sides of the camera front.
      • Installation Notes: Use contact cement to reapply the leatherette. This should be the very last step in reassembly, after the camera is tested and functionality is confirmed.
      Vraag FixBot
      Voeg opmerking toe
    8. Pentax ME Super Mirror Box Service, Remove mirror box screws: stap 15, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove mirror box screws: stap 15, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove mirror box screws: stap 15, afbeelding 3 van 3
      • Remove two 3.4 mm #00 screws.
      • Remove flex PCB retainer.
      • Remove shim washers. Note the location (left or right) and install in the same positions during reassembly.
      Vraag FixBot
      Voeg opmerking toe
    9. Pentax ME Super Mirror Box Service, Unscrew front plate: stap 16, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Unscrew front plate: stap 16, afbeelding 2 van 2
      • Remove four 4.0 mm #0 screws.
      Vraag FixBot
      Voeg opmerking toe
    10. Pentax ME Super Mirror Box Service, Remove front block assembly: stap 17, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Remove front block assembly: stap 17, afbeelding 2 van 2
      • Temporarily replace the advance lever and cock the shutter.
      • Gently lift the front block away from the camera body. Move slowly and look for wire snags.
      Vraag FixBot
      Voeg opmerking toe
    11. Pentax ME Super Mirror Box Service, Installation Notes: Front Block: stap 18, afbeelding 1 van 1
      • Cock the shutter on the camera body. The mirror box should be uncharged before installation.
      • Twist the three motor drive wires together to easily insert them through the bottom of the camera.
      • Carefully track wire routing during installation. Make sure nothing is getting pinched and that all wires are accessible for resoldering.
      • Once the front block is in place, check the mechanical speeds of the shutter before completing the reassembly. The mirror and shutter should function normally.
      Vraag FixBot
      Voeg opmerking toe
    1. Pentax ME Super Mirror Box Service, Detach viewfinder LEDs: stap 19, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Detach viewfinder LEDs: stap 19, afbeelding 2 van 2
      • Remove one 3.4 mm #00 screw.
      • Gently work the LED strip out of the slot in the mirror box until it hangs free.
      • The old dust/light seal foam will probably fall apart when the LEDs are removed. It should be replaced with new foam strips during reassembly (1.5 mm open cell foam with adhesive backing).
      • Installation Notes: The LEDs will need to be realigned with the text in the viewfinder. Use the play in the screw to properly position them.
      Vraag FixBot
      Voeg opmerking toe
    2. Pentax ME Super Mirror Box Service, Detach eye piece: stap 20, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Detach eye piece: stap 20, afbeelding 2 van 2
      • Unsolder one gray wire (flash sync).
      • Slide eye piece out of its metal frame. It is still attached to the main flex PCB.
      Vraag FixBot
      Voeg opmerking toe
    3. Pentax ME Super Mirror Box Service, Remove main flex PCB: stap 21, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove main flex PCB: stap 21, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove main flex PCB: stap 21, afbeelding 3 van 3
      • The PCB is attached to the prism with double sided tape.
      • Use isopropyl alcohol to loosen the adhesive and gently work the PCB free from the prism. Work slowly.
      • Pull the PCB out of the slot connector at the base of the mirror box.
      Vraag FixBot
      Voeg opmerking toe
    1. Pentax ME Super Mirror Box Service, Detach PCB connector: stap 22, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Detach PCB connector: stap 22, afbeelding 2 van 2
      • Unsolder two purple wires.
      • Unsolder one orange wire.
      • Unsolder one black wire.
      • Pull PCB connector away from mirror box.
      Vraag FixBot
      Voeg opmerking toe
    2. Pentax ME Super Mirror Box Service, Remove front plate from mirror box: stap 23, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove front plate from mirror box: stap 23, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove front plate from mirror box: stap 23, afbeelding 3 van 3
      • Remove four 5.7 mm #0 screws.
      • Work mirror box out of the front plate.
      Vraag FixBot
      Voeg opmerking toe
    3. Pentax ME Super Mirror Box Service, Installation Notes: Mirror Box: stap 24, afbeelding 1 van 1
      • Pay close attention to the routing of the purple and gray wires on the left side.
      • Make sure the mirror release lever (on the front plate) is properly coupled with the mirror release latch (on the mirror box).
      Vraag FixBot
      Voeg opmerking toe
    4. Pentax ME Super Mirror Box Service, Problem areas: stap 25, afbeelding 1 van 1
      • The rubber bushing under this screw causes the most problems. As it degrades it prevents the lever from moving freely leading to stuck mirrors and other malfunctions.
      • Removing this lever and cleaning out the old bushing is usually enough to get the camera functioning again.
      • Complete disassembly and cleaning out additional degraded bushings is recommended for the long term health of the camera.
      Vraag FixBot
      Voeg opmerking toe
      • This is what a properly function mirror box should look like.
      • The mirror release latch, mirror return latch, and shutter release lever all move freely. The bias springs keep them in their ready positions.
      • The mirror is charged by pushing the large post on the bottom towards the front of the camera.
      • Push the mirror release latch up to start the cycle. The mirror should move quickly to the taking position.
      • Push the mirror return linkage and the mirror to should move to the viewing position.
      Vraag FixBot
      Voeg opmerking toe
    5. Pentax ME Super Mirror Box Service, Remove mirror return linkage: stap 27, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove mirror return linkage: stap 27, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove mirror return linkage: stap 27, afbeelding 3 van 3
      • Remove one 3.2 mm flat head screw.
      • Remove one shim washer.
      • Remove one 3.5 mm flat head screw.
      • Remove degraded rubber bushing.
      • Clean thoroughly with isopropyl alcohol.
      Vraag FixBot
      Voeg opmerking toe
    6. Pentax ME Super Mirror Box Service, Remove shutter release lever: stap 28, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Remove shutter release lever: stap 28, afbeelding 2 van 2
      • Remove one 2.9 mm #00 screw.
      • Remove release lever.
      • Remove bias spring and brass bushing.
      • Installation Notes: Make sure the lever moves freely and the bias spring is properly attached.
      Vraag FixBot
      Voeg opmerking toe
    7. Pentax ME Super Mirror Box Service, Remove mirror return latch: stap 29, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove mirror return latch: stap 29, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove mirror return latch: stap 29, afbeelding 3 van 3
      • Remove one c-clip.
      • Remove shim washer and bias spring.
      • Remove mirror return latch.
      Vraag FixBot
      Voeg opmerking toe
    8. Pentax ME Super Mirror Box Service, Remove mirror release latch: stap 30, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove mirror release latch: stap 30, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove mirror release latch: stap 30, afbeelding 3 van 3
      • Remove mirror release latch.
      • Remove bias spring.
      • Remove shim washer.
      • Remove mirror up lever.
      Vraag FixBot
      Voeg opmerking toe
    9. Pentax ME Super Mirror Box Service, Remove mirror actuator lever: stap 31, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove mirror actuator lever: stap 31, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove mirror actuator lever: stap 31, afbeelding 3 van 3
      • Remove tension spring.
      • Remove one 4.0 mm #00 screw and washer.
      • Remove mirror actuator lever
      • White plastic bushing is loose and may fall off.
      • Remove shim washers if present.
      Vraag FixBot
      Voeg opmerking toe
    10. Pentax ME Super Mirror Box Service, Remove aperture coupling lever: stap 32, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Remove aperture coupling lever: stap 32, afbeelding 2 van 2
      • Remove the aperture coupling lever.
      • Installation Notes: Properly couple the aperture lever and the mirror actuator lever with the levers on the bottom of the mirror box.
      Vraag FixBot
      Voeg opmerking toe
    11. Pentax ME Super Mirror Box Service, Remove and replace degraded bumpers: stap 33, afbeelding 1 van 2 Pentax ME Super Mirror Box Service, Remove and replace degraded bumpers: stap 33, afbeelding 2 van 2
      • Remove two rubber bumpers and clean thoroughly with isopropyl alcohol.
      • Clean all pivots and mechanical components with isopropyl alcohol before reassembly.
      • Replacement bumpers are not required but new parts can be made from the insulation of 12 gage silicon wire.
      Vraag FixBot
      Voeg opmerking toe
    12. Pentax ME Super Mirror Box Service, Remove shock absorber lever: stap 34, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove shock absorber lever: stap 34, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove shock absorber lever: stap 34, afbeelding 3 van 3
      • Unhook tensioning spring.
      • Remove one 3.4 mm flat head screw.
      • Remove shock absorber lever.
      • Remove two washers.
      Vraag FixBot
      Voeg opmerking toe
    13. Pentax ME Super Mirror Box Service, Remove air damper: stap 35, afbeelding 1 van 3 Pentax ME Super Mirror Box Service, Remove air damper: stap 35, afbeelding 2 van 3 Pentax ME Super Mirror Box Service, Remove air damper: stap 35, afbeelding 3 van 3
      • Push mirror charge lever aside and remove air damper.
      • Separate the halves of the air damper and remove degraded rubber bumper.
      • Replace if new parts are available.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
  • To reassemble your device, follow these instructions in reverse order.
  • No lubrication is required for the mirror box mechanism. All of the pivot points are left dry.
  • A thick molybdenum grease can be used on the latching points to reduce wear.
5 andere personen hebben deze handleiding voltooid.
Sam Gustafson
14.444 Reputatie
78 handleidingen geschreven
1Gids Commentaar
What a fabulously detailed guide you have produced here, quite fantastic. The detailed diagrams with their colour-coded arrows showing exactly where things are works wonderfully. The amount of work to produce this and other guides must be in tremendous and is a great gift to the photographer repairer. Many thanks indeed. Mark
mark steed - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 116
Afgelopen 30 dagen: 431
Altijd: 6,414
