Ga door naar hoofdinhoud
Pentax LX Shutter Speed Resistor Cleaning
Wat je nodig hebt
  1. Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: stap 1, afbeelding 1 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: stap 1, afbeelding 2 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove winding lever: stap 1, afbeelding 3 van 3
    • Winding lever cover is reverse threaded.
    • Use a piece of tape wrapped sticky side out to grip the winding lever cover. Turn clockwise to loosen and remove
    • Remove four #000 2.5 mm screws.
    • Use spanners to remove top cover retaining nut.
    Vraag FixBot
    Voeg opmerking toe
  2. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: stap 2, afbeelding 1 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: stap 2, afbeelding 2 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed dial: stap 2, afbeelding 3 van 3
    • Gently remove the rubber covering around the shutter speed dial.
    • Remove three #000 1.6 mm screws.
    • Remove cover ring.
    • Installation Notes: After the camera has been fully tested, use a few dabs of contact cement to fix the rubber covering back in place.
    Vraag FixBot
    Voeg opmerking toe
  3. Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: stap 3, afbeelding 1 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: stap 3, afbeelding 2 van 3 Pentax LX Shutter Speed Resistor Cleaning, Remove wind side top cover: stap 3, afbeelding 3 van 3
    • Remove one #00 2.5 mm screw.
    • Remove one #00 X mm screw.
    • Lift off top cover.
    Vraag FixBot
    Voeg opmerking toe
  4. Pentax LX Shutter Speed Resistor Cleaning, Remove auto/manual switch: stap 4, afbeelding 1 van 1
    • Unhook lever spring.
    • Remove one #000 X mm screw.
    • Remove auto/manual switch lever.
    • This contact tells the camera what mode the shutter speed dial is set to: auto, manual (high speed mechanical), manual (low speed electronic), and bulb.
    Vraag FixBot
    Voeg opmerking toe
  5. Pentax LX Shutter Speed Resistor Cleaning, Remove timing switch assembly: stap 5, afbeelding 1 van 2 Pentax LX Shutter Speed Resistor Cleaning, Remove timing switch assembly: stap 5, afbeelding 2 van 2
    • Remove slotted nut. Use isopropyl alcohol to soften thread lock if necessary.
    • Remove all components of the timing switch assembly.
    Vraag FixBot
    Voeg opmerking toe
  6. Pentax LX Shutter Speed Resistor Cleaning, Lock viewfinder needle indicator: stap 6, afbeelding 1 van 2 Pentax LX Shutter Speed Resistor Cleaning, Lock viewfinder needle indicator: stap 6, afbeelding 2 van 2
    • Turn shutter speed selector to 'Auto'.
    • Turn lock lever screw clockwise to loosen. Do not remove.
    • Lock lever screw is reverse threaded.
    • Push lock lever toward the needle indicator gear.
    • Turn lock lever screw counter-clockwise to tighten.
    • Locking the needle indicator keeps it in the proper position once the shutter dial assembly is removed.
    Vraag FixBot
    Voeg opmerking toe
  7. Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed selector assembly: stap 7, afbeelding 1 van 2 Pentax LX Shutter Speed Resistor Cleaning, Remove shutter speed selector assembly: stap 7, afbeelding 2 van 2
    • Unsolder two yellow wires.
    • Remove one #00 4.0 mm screw.
    • Remove one #00 2.2 mm screw.
    • Remove high speed cam.
    • Installation Note: Set dial to 'Auto' before installing. After install, unlock the viewfinder indicator and check that it is showing the correct speeds in the viewfinder as the dial is turned.
    Vraag FixBot
    Voeg opmerking toe
  8. Pentax LX Shutter Speed Resistor Cleaning, Clean speed resistor: stap 8, afbeelding 1 van 2 Pentax LX Shutter Speed Resistor Cleaning, Clean speed resistor: stap 8, afbeelding 2 van 2
    • Rotate the speed dial until the feeler contacts are visible in the gap.
    • Spray with a plastic safe contact cleaner and rotate back and forth.
    • Check the resistor values at the slow speed settings. They should range from around 9 kΩ (at 60) to 200 kΩ (at 4s) with no dead spots.
    • Clean the seat for the high speed cam with isopropyl alcohol. A narrow cotton bud or a floss pick work well.
    • Lubricate the high speed cam seat with shutter oil.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sam Gustafson
14.384 Reputatie
78 handleidingen geschreven
8Gids Commentaar
Hello everyone. I have an LX that initially couldn't lower the mirror or release the second shutter curtain. It turned out to be a broken speed sensor wire within the mirror box mechanism. After that, I removed and cleaned the speed potentiometer, and now the shutter only operates at one speed. Any suggestions on how to fix this?
Trọng Nguyễn Đức - Antwoord Deel
Just to clarify, you're saying as you change the shutter speed dial to different settings, it keeps firing at the same speed? If that is the case, my guess would be a short around the speed selector assembly. If the camera sees 0 Ohms at he speed selector, it would be stuck in a single speed. I would double check your soldering and check the resistance at the point where the yellow wires connect if your have a DMM.
Sam Gustafson - Antwoord Deel
That's right. I changed the speed dial, but the shutter speed didn't change. Today, I measured the resistance value, and it still gave different values at each speed. However, the shutter speed still didn't change. I suspect it's either stuck or I've incorrectly assembled the speed cam. I'm currently unsure which part of the mechanism it is. Thank you for your response
I cleaned the resistor. However after doing this I have two problems :
1. I am not sure how to put back high speed cam.
2. When I loosened the needle indicator screw and now I cannot adjust it properly. It seems that whenever I turn the speed selector it moves the needle half way.
Can you please help me.
Ivan Yanakiev - Antwoord Deel
1. The high speed cam just kind of sits on top of the wind gears. The only thing to note, which isn't shown very well in the photos, is to make sure the small peg on the wind gear sits in the slot of the high speed cam.
2. Sounds like the gear on the speed selector assembly is not meshing properly with the gear driving the viewfinder display. I would just try removing and reassembling.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 67
Altijd: 893
