Ga door naar hoofdinhoud
Pebble Steel Vibration Motor Replacement
Wat je nodig hebt
    1. Pebble Steel Vibration Motor Replacement, Internal Hardware: stap 1, afbeelding 1 van 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: stap 1, afbeelding 2 van 3 Pebble Steel Vibration Motor Replacement, Internal Hardware: stap 1, afbeelding 3 van 3
      • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
      • Make sure the screws are kept in a safe place to insure they are not lost.
      • Remove the back plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Pebble Steel Vibration Motor Replacement: stap 2, afbeelding 1 van 2 Pebble Steel Vibration Motor Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
      • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
      • Adhesive on the back side of the battery holds the internal components to the front case.
      • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Pebble Steel Vibration Motor Replacement, Vibration Motor: stap 3, afbeelding 1 van 1
      • Use a small plastic opening tool to remove the vibration motor from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Pebble Steel Vibration Motor Replacement: stap 4, afbeelding 1 van 1
      • Use a pair of tweezers to detach both the blue and red wires from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Orlandria Heggs
545 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-7, Leahy Fall 2015 Lid van USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Leden
7 handleidingen geschreven
2Gids Commentaar
Any idea where I can get the vibration motor ?
Armacalypse Roguewind - Antwoord Deel
Do you think these would be ok as a replacement for my pebble (original, first gen.) http://www.ebay.it/itm/5-Motorino-Motore...
cerebro84 - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 41
Altijd: 3,860
