Ga door naar hoofdinhoud
Pebble Steel Buttons Replacement
Wat je nodig hebt
    1. Pebble Steel Buttons Replacement, Internal Hardware: stap 1, afbeelding 1 van 3 Pebble Steel Buttons Replacement, Internal Hardware: stap 1, afbeelding 2 van 3 Pebble Steel Buttons Replacement, Internal Hardware: stap 1, afbeelding 3 van 3
      • Use a Torx T3 screwdriver to unscrew the four 3.5 mm Torx T3 screws holding the back plate.
      • Make sure the screws are kept in a safe place to insure they are not lost.
      • Remove the back plate.
      Vraag FixBot
      Voeg opmerking toe
    2. Pebble Steel Buttons Replacement: stap 2, afbeelding 1 van 2 Pebble Steel Buttons Replacement: stap 2, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • The plastic frame is clipped inside the steel body with four clips, two each on the left and the right side of the watch, near the corners. You can stick a small screwdriver into the cutouts right above the clips and gently lever the plastic frame up, corner by corner.
      • Once the clips are released, use a pair of tweezers to grab onto the black plastic frame and remove the internal hardware.
      • Adhesive on the back side of the battery holds the internal components to the front case.
      • Use tweezers or a plastic opening tool to disconnect the ribbon cable from the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    1. Pebble Steel Buttons Replacement, Buttons: stap 3, afbeelding 1 van 1
      • Starting in the top right corner, use a pair of tweezers to remove the white film.
      Vraag FixBot
      Voeg opmerking toe
    2. Pebble Steel Buttons Replacement: stap 4, afbeelding 1 van 2 Pebble Steel Buttons Replacement: stap 4, afbeelding 2 van 2
      • Continue pulling off the attached orange Zebra ribbon and the inner sensors attached to the ribbon.
      • If pieces of the orange Zebra ribbon remain on the frame, remove them.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Orlandria Heggs
545 Reputatie
3 handleidingen geschreven
USF Tampa, Team 1-7, Leahy Fall 2015 Lid van USF Tampa, Team 1-7, Leahy Fall 2015
USFT-LEAHY-F15S1G7
3 Leden
7 handleidingen geschreven
9Gids Commentaar
Where do I get a new zebra ribbon? I can't fond any on the intetnrt?
Knocky ledwell - Antwoord Deel
I also can't find the zebra cable. Any information on this?
eliasp02 - Antwoord Deel
Generally I'm a big fan of iFixit and the tear down guides but this one is seriously lacking. Firstly, there is no indication of where to get replacement parts. I understand that Pebble do not have a solution to supply repair parts to the market meaning that a tear down is a pointless exercise as the item is junk if it's broken. There also aren't any third party suppliers that I can see. The next problem with this one is that during disassembly the button ribbon cable was torn and it seems no mention was made that it is now unusable. More photos are required and a big warning that the cable will tear easily when pulling it away from the adhesive.
Otherwise keep up the good work ifixit
Martin Le Tessier - Antwoord Deel
This tutorial isn’t so good. It’s missing parts and where the !&&* you got a new zebra cable?
Emilio Jéldrez - Antwoord Deel
If the buttons are not working. The only way to fix the issue is to solder a small wire on the zebra ribbon. I did it and the buttons are working fine again.
Nicolas V. - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 66
Altijd: 10,145
