Ga door naar hoofdinhoud
Parrot Skycontroller 2 Power Port Replacement
Wat je nodig hebt
  1. Parrot Skycontroller 2 Power Port  Replacement, Power Port: stap 1, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: stap 1, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement, Power Port: stap 1, afbeelding 3 van 3
    • Flip the controller upside down.
  2. Parrot Skycontroller 2 Power Port  Replacement: stap 2, afbeelding 1 van 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
  3. Parrot Skycontroller 2 Power Port  Replacement: stap 3, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 3, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool into the top of the battery cover and pry upwards to lift the cover.
    • Remove the cover by pulling up and out.
  4. Parrot Skycontroller 2 Power Port  Replacement: stap 4, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 4, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 4, afbeelding 3 van 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling apart.
  5. Parrot Skycontroller 2 Power Port  Replacement: stap 5, afbeelding 1 van 2 Parrot Skycontroller 2 Power Port  Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from it's brackets by pulling up gently on the ends of the battery.
    • Some force may be required to separate the battery from it's brackets.
  6. Parrot Skycontroller 2 Power Port  Replacement: stap 6, afbeelding 1 van 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver.
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screw using the Torx TR6 screwdriver.
  7. Parrot Skycontroller 2 Power Port  Replacement: stap 7, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 7, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 7, afbeelding 3 van 3
    • Remove the seven silver 4mm screws from around the edge of the top panel using the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
  8. Parrot Skycontroller 2 Power Port  Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery compartment plate by pulling up and out.
  9. Parrot Skycontroller 2 Power Port  Replacement: stap 9, afbeelding 1 van 1
    • Remove the top plate by pushing on the corners with your hand.
    • Be careful to not pull too hard on the cable.
  10. Parrot Skycontroller 2 Power Port  Replacement: stap 10, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 10, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 10, afbeelding 3 van 3
    • Remove the face plate by pulling up and out.
  11. Parrot Skycontroller 2 Power Port  Replacement: stap 11, afbeelding 1 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 11, afbeelding 2 van 3 Parrot Skycontroller 2 Power Port  Replacement: stap 11, afbeelding 3 van 3
    • Make sure the controller is flat, then proceed to desolder the power port.
    • Desolder the four connection points surrounding the charging port.
    • Remove the power port from the controller.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • Excessive heat can damage the power port, so do not apply the soldering iron to the component for too long.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 480
