Ga door naar hoofdinhoud
Parrot Skycontroller 2 Joystick Replacement
Wat je nodig hebt
  1. Parrot Skycontroller 2 Joystick Replacement, Battery: stap 1, afbeelding 1 van 3 Parrot Skycontroller 2 Joystick Replacement, Battery: stap 1, afbeelding 2 van 3 Parrot Skycontroller 2 Joystick Replacement, Battery: stap 1, afbeelding 3 van 3
    • Flip your controller face down.
    Vraag FixBot
    Voeg opmerking toe
  2. Parrot Skycontroller 2 Joystick Replacement: stap 2, afbeelding 1 van 1
    • Remove one 9mm screw using a #4 flathead screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Parrot Skycontroller 2 Joystick Replacement: stap 3, afbeelding 1 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 3, afbeelding 2 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 3, afbeelding 3 van 3
    • Insert the plastic opening tool into the top of the cover and pry upwards to lift the battery cover.
    • Remove the cover by pulling up and out.
    Vraag FixBot
    Voeg opmerking toe
  4. Parrot Skycontroller 2 Joystick Replacement: stap 4, afbeelding 1 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 4, afbeelding 2 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 4, afbeelding 3 van 3
    • Pull the connectors out by gently pushing the tabs and pulling up on the connector.
    • Disconnect the battery from the remote by pressing the white tab and pulling the connectors apart.
    Vraag FixBot
    Voeg opmerking toe
  5. Parrot Skycontroller 2 Joystick Replacement: stap 5, afbeelding 1 van 2 Parrot Skycontroller 2 Joystick Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from its brackets by pulling up on the ends of the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. Parrot Skycontroller 2 Joystick Replacement, Joystick: stap 6, afbeelding 1 van 1
    • Remove the seven black 11mm screws using the Torx TR6 screwdriver
    • There is a hidden screw located behind the sticker in the battery compartment.
    • Pull back the sticker with your finger nail and remove the one black 11mm screws using the Torx TR6 screwdriver
    Vraag FixBot
    Voeg opmerking toe
  7. Parrot Skycontroller 2 Joystick Replacement: stap 7, afbeelding 1 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 7, afbeelding 2 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 7, afbeelding 3 van 3
    • Remove the seven silver 4mm screws from around the edge of the top plate with the Torx TR6 Screwdriver.
    • The opposite side to the third picture has a screw located on each side of the USB port.
    Vraag FixBot
    Voeg opmerking toe
  8. Parrot Skycontroller 2 Joystick Replacement: stap 8, afbeelding 1 van 1
    • Remove the battery compartment plate by pulling up and out.
    Vraag FixBot
    Voeg opmerking toe
  9. Parrot Skycontroller 2 Joystick Replacement: stap 9, afbeelding 1 van 1
    • Remove the top plate by pushing out on the corners with your hand.
    • Be careful to not pull too hard on the cable.
    Vraag FixBot
    Voeg opmerking toe
  10. Parrot Skycontroller 2 Joystick Replacement: stap 10, afbeelding 1 van 2 Parrot Skycontroller 2 Joystick Replacement: stap 10, afbeelding 2 van 2
    • Remove the face plate by pulling up and out.
    • Buttons will fall out when this plate is removed.
    Vraag FixBot
    Voeg opmerking toe
  11. Parrot Skycontroller 2 Joystick Replacement: stap 11, afbeelding 1 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 11, afbeelding 2 van 3 Parrot Skycontroller 2 Joystick Replacement: stap 11, afbeelding 3 van 3
    • Firmly grasp the end of either joystick.
    • Pull the joystick up and out while grasping the other side of the controller.
    • Once both joysticks have been removed, this is what it should look like.
    • Some force may be needed to remove the joysticks.
    • Repeat this process for the other side as well.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 26
Altijd: 757
