Ga door naar hoofdinhoud
Parrot AR.Drone 2.0 Central Cross Replacement
Wat je nodig hebt
Video overzicht
  1. Parrot AR.Drone 2.0 Central Cross Replacement, Mainboard and Navigation Board: stap 1, afbeelding 1 van 1
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Central Cross Replacement: stap 2, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Central Cross Replacement: stap 3, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 3, afbeelding 2 van 2
    • Turn the drone upside down.
    • The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
  4. Parrot AR.Drone 2.0 Central Cross Replacement: stap 4, afbeelding 1 van 3 Parrot AR.Drone 2.0 Central Cross Replacement: stap 4, afbeelding 2 van 3 Parrot AR.Drone 2.0 Central Cross Replacement: stap 4, afbeelding 3 van 3
    • Using a spudger, separate the connector for the downward camera.
    • Remove the camera from the body by pulling it off the foam body.
  5. Parrot AR.Drone 2.0 Central Cross Replacement: stap 5, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 5, afbeelding 2 van 2
    • Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
    • Use tweezers to carefully remove the ribbon from the connector.
    How can I get that connector, the one it’s disconnected?
    gui txr - Antwoord
  6. Parrot AR.Drone 2.0 Central Cross Replacement: stap 6, afbeelding 1 van 1
    • Remove the four 8mm torx screws with a T6 bit.
    • Remove the four 8mm philips head screws with a PH00 bit.
  7. Parrot AR.Drone 2.0 Central Cross Replacement: stap 7, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 7, afbeelding 2 van 2
    • Carefully pull the secondary board from the mainboard.
  8. Parrot AR.Drone 2.0 Central Cross Replacement: stap 8, afbeelding 1 van 3 Parrot AR.Drone 2.0 Central Cross Replacement: stap 8, afbeelding 2 van 3 Parrot AR.Drone 2.0 Central Cross Replacement: stap 8, afbeelding 3 van 3
    • Turn the drone right side up
    • Remove the USB connector from the battery retaining straps.
  9. Parrot AR.Drone 2.0 Central Cross Replacement: stap 9, afbeelding 1 van 1
    • Release the rubber clip holding the USB and battery power cable to the body.
  10. Parrot AR.Drone 2.0 Central Cross Replacement: stap 10, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 10, afbeelding 2 van 2
    • Avoid using sharp tools near the battery.
    • Push the USB and power cable through the battery panel.
  11. Parrot AR.Drone 2.0 Central Cross Replacement: stap 11, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 11, afbeelding 2 van 2
    • Turn the drone upside down again.
    • Use a spudger to release the connector and carefully remove the ribbon.
  12. Parrot AR.Drone 2.0 Central Cross Replacement: stap 12, afbeelding 1 van 2 Parrot AR.Drone 2.0 Central Cross Replacement: stap 12, afbeelding 2 van 2
    • Lift the mainboard up so that you can access the back.
    • Disconnect the first connector with the white wires using a nylon spudger.
    • Disconnect the second connector with the red and black wires using a spudger.
  13. Parrot AR.Drone 2.0 Central Cross Replacement: stap 13, afbeelding 1 van 1
    • The mainboard is now fully detached and can be removed.
  14. Parrot AR.Drone 2.0 Central Cross Replacement, Central Cross: stap 14, afbeelding 1 van 1
    • Using a nylon spudger, peel off the four pieces of plastic securing the frame to the body.
  15. Parrot AR.Drone 2.0 Central Cross Replacement: stap 15, afbeelding 1 van 1
    • Carefully maneuver the four arms of the drone’s central cross until it detaches from the body by pulling apart the foam surrounding the arms.
    between arm 1 and arm 2 there is a little triangle on the central cross, that should point to the front.
    deebee122 - Antwoord
  16. Parrot AR.Drone 2.0 Central Cross Replacement: stap 16, afbeelding 1 van 1
    • The central cross can now be removed and replaced.
Conclusie
4 andere personen hebben deze handleiding voltooid.
David Hoyt
4.023 Reputatie
43 handleidingen geschreven
Cal Poly, Team 25-89, Amido Spring 2010 Lid van Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Leden
63 handleidingen geschreven
2 opmerkingen
If the crossbones are off just a bit would that effect the flight?
John Wurst - Antwoord
So once I have removed the central cross, how do I put it all back together again?? I feel as though this is letting your guide down!!!!
Jacob Kenworthy - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 6,137
