Ga door naar hoofdinhoud
Panasonic SC-PM31 Fan Replacement
Wat je nodig hebt
  1. Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: stap 1, afbeelding 1 van 3 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: stap 1, afbeelding 2 van 3 Panasonic SC-PM31 Fan Replacement, Removing the side and back screws: stap 1, afbeelding 3 van 3
    • Remove the five 9 mm #2 Phillips screws from the side panel nearest the power button.
    • Repeat the process for the opposite panel.
    • Remove the two 15 mm #2 Phillips screws from the back of the top panel.
    • Remove the middle 10mm #2 Phillips screw from the back of the top panel.
    Vraag FixBot
    Voeg opmerking toe
  2. Panasonic SC-PM31 Fan Replacement, Removing the panels: stap 2, afbeelding 1 van 2 Panasonic SC-PM31 Fan Replacement, Removing the panels: stap 2, afbeelding 2 van 2
    • If you do not have a plastic opening tool, you can open the system using your finger. However, if you choose to use your hands, make sure to wear gloves. The panel is very sharp.
    • Swing the back half of the panel slightly away from the unit. Then, starting at the top back corner, slide plastic opening tool through the created gap from back to front. The panel should pop off. Repeat the process on the opposite panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Panasonic SC-PM31 Fan Replacement, Removing the white ribbon wire: stap 3, afbeelding 1 van 1
    • Looking in through the side nearest the power button, use your fingers to pull the white ribbon connection toward you, away from the rear circuit board.
    • The process will require the use of moderate force and can be eased by wiggling the ribbon during removal.
    Vraag FixBot
    Voeg opmerking toe
  4. Panasonic SC-PM31 Fan Replacement, Removing the top panel: stap 4, afbeelding 1 van 2 Panasonic SC-PM31 Fan Replacement, Removing the top panel: stap 4, afbeelding 2 van 2
    • Remove the top panel. You will need to slightly bend the plastic tab outwards, to undo the clasp that is attached to the top.
    • When reassembling the device, reattach the white ribbon wire (Step 3) before replacing the top panel.
    Vraag FixBot
    Voeg opmerking toe
  5. Panasonic SC-PM31 Fan Replacement, Removing the back panel screws: stap 5, afbeelding 1 van 1
    • Remove the eight 9.5 mm #2 Phillips screws attaching the back to the device.
    Vraag FixBot
    Voeg opmerking toe
  6. Panasonic SC-PM31 Fan Replacement, Removing the back panel: stap 6, afbeelding 1 van 3 Panasonic SC-PM31 Fan Replacement, Removing the back panel: stap 6, afbeelding 2 van 3 Panasonic SC-PM31 Fan Replacement, Removing the back panel: stap 6, afbeelding 3 van 3
    • With a gentle tug, unplug the red and black cable from the tan circuit board.
    • Using both hands, unlock the plastic back panel from the metal clasps (located on the sides of the unit) by pulling the plastic away from the metal. Focus on undoing first one clasp, then the other.
    • Slide the back panel toward you and off of the unit.
    Vraag FixBot
    Voeg opmerking toe
  7. Panasonic SC-PM31 Fan Replacement, Removing the fan.: stap 7, afbeelding 1 van 3 Panasonic SC-PM31 Fan Replacement, Removing the fan.: stap 7, afbeelding 2 van 3 Panasonic SC-PM31 Fan Replacement, Removing the fan.: stap 7, afbeelding 3 van 3
    • Flip the back panel over and locate the four clasps holding the fan in place.
    • One by one, unlock each clasp by pulling it outwards and gently lifting the fan up and away from it.
    • Remove the fan by lifting it gently away from the back panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Jessica Chao
650 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-7, Forte Fall 2014 Lid van Cal Poly, Team 13-7, Forte Fall 2014
CPSU-FORTE-F14S13G7
5 Leden
14 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 1,506
