Ga door naar hoofdinhoud
Panasonic SA-HT810V VHS Drive Replacement
Wat je nodig hebt
    1. Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: stap 1, afbeelding 1 van 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: stap 1, afbeelding 2 van 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: stap 1, afbeelding 3 van 3
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • All screws will need to be removed with a phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic SA-HT810V VHS Drive Replacement: stap 2, afbeelding 1 van 2 Panasonic SA-HT810V VHS Drive Replacement: stap 2, afbeelding 2 van 2
      • Rotate the device so that the back faces you.
      • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic SA-HT810V VHS Drive Replacement: stap 3, afbeelding 1 van 1
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic SA-HT810V VHS Drive Replacement: stap 4, afbeelding 1 van 3 Panasonic SA-HT810V VHS Drive Replacement: stap 4, afbeelding 2 van 3 Panasonic SA-HT810V VHS Drive Replacement: stap 4, afbeelding 3 van 3
      • Pull up the two tabs on top
      • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Panasonic SA-HT810V VHS Drive Replacement: stap 5, afbeelding 1 van 1
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      Vraag FixBot
      Voeg opmerking toe
    6. Panasonic SA-HT810V VHS Drive Replacement: stap 6, afbeelding 1 van 2 Panasonic SA-HT810V VHS Drive Replacement: stap 6, afbeelding 2 van 2
      • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
      Vraag FixBot
      Voeg opmerking toe
    7. Panasonic SA-HT810V VHS Drive Replacement: stap 7, afbeelding 1 van 1
      • Remove the three cables attaching the VHS to the Mother Board.
      • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
      • Make sure the cables connecting the VHS Drive are fully inserted before powering the machine on to prevent damage to the internal components.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nathan Cheadle
161 Reputatie
7 handleidingen geschreven
Cal Poly, Team 16-5, Maness Spring 2010 Lid van Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 38
Altijd: 1,509
