Ga door naar hoofdinhoud
Panasonic SA-HT810V DVD Drive Replacement
Wat je nodig hebt
    1. Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: stap 1, afbeelding 1 van 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: stap 1, afbeelding 2 van 3 Panasonic SA-HT810V DVD Drive Replacement, DVD Drive: stap 1, afbeelding 3 van 3
      • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
      • Now rotate the device 180 degrees and remove the second screw.
      • Remove the screw that is on the right side of the panel facing you.
      • Remove all screws with a phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic SA-HT810V DVD Drive Replacement: stap 2, afbeelding 1 van 2 Panasonic SA-HT810V DVD Drive Replacement: stap 2, afbeelding 2 van 2
      • Rotate the device so that the back faces you.
      • Using a phillips head screw driver, locate and remove the two screws highlighted by the red circles in image one.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic SA-HT810V DVD Drive Replacement: stap 3, afbeelding 1 van 1
      • Before removing cover make sure that the back of the device is facing you.
      • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic SA-HT810V DVD Drive Replacement: stap 4, afbeelding 1 van 3 Panasonic SA-HT810V DVD Drive Replacement: stap 4, afbeelding 2 van 3 Panasonic SA-HT810V DVD Drive Replacement: stap 4, afbeelding 3 van 3
      • Pull up the two tabs on top
      • Pull the the three tabs on the side. One is on the left, and two are on the right side of the device when it is facing you.
      • Depress the four tabs on the bottom of the device with a flat head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Panasonic SA-HT810V DVD Drive Replacement: stap 5, afbeelding 1 van 1
      • Carefully pull off the front panel of the device.
      • The front is attached to the device with cables so be careful when removing.
      Vraag FixBot
      Voeg opmerking toe
    6. Panasonic SA-HT810V DVD Drive Replacement: stap 6, afbeelding 1 van 2 Panasonic SA-HT810V DVD Drive Replacement: stap 6, afbeelding 2 van 2
      • Remove the four screws around the DVD drive with a phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Panasonic SA-HT810V DVD Drive Replacement: stap 7, afbeelding 1 van 1
      • The DVD player is attached to the power supply.
      • Remove the wire attaching it by firmly pulling on the wire until it releases.
      Vraag FixBot
      Voeg opmerking toe
    8. Panasonic SA-HT810V DVD Drive Replacement: stap 8, afbeelding 1 van 1
      • Flip the DVD drive so that the bottom is facing you.
      • Pull on the blue ribbon cable until it releases.
      • To place the new DVD drive in just follow these steps in reverse.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nathan Cheadle
161 Reputatie
7 handleidingen geschreven
Cal Poly, Team 16-5, Maness Spring 2010 Lid van Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 36
Altijd: 2,008
