Ga door naar hoofdinhoud
Panasonic Lumix ZS50 Flash Assembly Replacement
Wat je nodig hebt
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: stap 1, afbeelding 1 van 2 Panasonic Lumix ZS50 Flash Assembly Replacement, Battery: stap 1, afbeelding 2 van 2
      • Turn the camera off and identify the battery door located on the bottom of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 2, afbeelding 2 van 2
      • Slide the "open" latch to the left: the battery door should spring open.
      • If your battery door doesn't open you may have to pry it open using a plastic opening tool or a standard spudger.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 3, afbeelding 1 van 1
      • To release the battery, slide the white release lever next to the SD card slot.
      • If you find the battery release lever to be jammed you can push it using a plastic opening tool or standard spudger.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 4, afbeelding 1 van 1
      • The battery should now be released; you may now remove the battery from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: stap 5, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: stap 5, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, LCD Screen: stap 5, afbeelding 3 van 3
      • Orient the camera so the bottom is facing up and the battery door is on the right side.
      • Remove four black screws from the bottom of the camera.
      • Remove two black screws from the right side of the camera.
      • Remove one black screw from the left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 6, afbeelding 1 van 2 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 6, afbeelding 2 van 2
      • Remove the casing from the camera by hand or using a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 7, afbeelding 1 van 2 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 7, afbeelding 2 van 2
      • Use a spudger to lift up and tug off the green button board.
      • Be careful to not damage the attached ribbon cable.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 8, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 8, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 8, afbeelding 3 van 3
      • Remove the screen using the plastic opening tool, prying from the top.
      • Once it's lifted up, tug lightly on the large ribbon cable to detach the screen from the camera body.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: stap 9, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: stap 9, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Lens Assembly: stap 9, afbeelding 3 van 3
      • Remove the three screws from the center of the copper plate.
      • Remove the four screws from the outer edges of the copper plate.
      • Use a plastic or metal spudger to pry the copper plate out of place.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 10, afbeelding 1 van 2 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 10, afbeelding 2 van 2
      • Remove the casing from the circuitboard by hand.
      • Remove the HDMI port casing by hand.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 11, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 11, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 11, afbeelding 3 van 3
      • Disconnect all orange ribbon cables connecting to the circuitboard by hand.
      • Disconnect the circuitboard by hand.
      • There will be one orange ribbon cable attached to the top that can now be removed.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 12, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 12, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 12, afbeelding 3 van 3
      • Remove the seven screws surrounding the lens assembly.
      • Move all ribbon cables out of your way while unscrewing.
      • Remove the three springs surrounding the lens.
      • Apply pressure on the front of the lens to push the lens out.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: stap 13, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: stap 13, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement, Flash Assembly: stap 13, afbeelding 3 van 3
      • Remove the one screw holding the camera and the flash component together.
      • Gently pull the flash component out of the camera body.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix ZS50 Flash Assembly Replacement: stap 14, afbeelding 1 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 14, afbeelding 2 van 3 Panasonic Lumix ZS50 Flash Assembly Replacement: stap 14, afbeelding 3 van 3
      • Separate the top camera casing from the flash component by unscrewing the three surrounding screws.
      • Remove the flash assembly, including the circuit board, by detaching it and the ribbon cables from the casing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bridget Lathrop
158 Reputatie
2 handleidingen geschreven
Baylor, Team 8-5, Whitney Spring 2017 Lid van Baylor, Team 8-5, Whitney Spring 2017
BU-WHITNEY-S17S8G5
3 Leden
16 handleidingen geschreven
1Gids Commentaar
Step 7: Does not mention the HDMI port door. Make sure you account for it
BayleeVersteeg - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 93
Altijd: 1,043
