Ga door naar hoofdinhoud
Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement
Wat je nodig hebt
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Battery: stap 1, afbeelding 1 van 1
      • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 2, afbeelding 1 van 2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 2, afbeelding 2 van 2
      • Push the small black tab that holds the battery with your finger to release the battery.
      • Use your fingers to pull the battery out of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: stap 3, afbeelding 1 van 3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: stap 3, afbeelding 2 van 3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Cover: stap 3, afbeelding 3 van 3
      • Using a Phillips #00 screwdriver, remove six 2.69mm, silver screws located on the two short sides of the camera and the bottom side.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 4, afbeelding 1 van 3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 4, afbeelding 2 van 3 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 4, afbeelding 3 van 3
      • Gently lift up the back cover to access the ZIF connectors for the blue and yellow ribbons.
      • To unlock the ZIF connectors, gently push the black portion of the lock from a flat position to an upright position using a spudger.
      • Take caution not to rip the ribbons out of the ZIF connectors when lifting the back panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 5, afbeelding 1 van 1
      • Gently push the blue and yellow ribbons out of the unlocked ZIF connectors using your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 6, afbeelding 1 van 1
      • Using a Phillips #00 screwdriver, remove the 3.5 mm silver screw from the upper left hand corner of the back cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 7, afbeelding 1 van 1
      • Using a spudger, lift up and remove the plastic cover piece from the back cover.
      • Plastic cover may fall off without prying.
      Vraag FixBot
      Voeg opmerking toe
    6. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 8, afbeelding 1 van 1
      • Using a Phillips #00 screwdriver, remove the 2.69 mm silver screw located beneath the plastic piece that was previously removed.
      Vraag FixBot
      Voeg opmerking toe
    7. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement: stap 9, afbeelding 1 van 1
      • Using a spudger, lift up and separate the heavier metal cover from the light, plastic back cover.
      • Metal cover may fall off without prying.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: stap 10, afbeelding 1 van 2 Panasonic Lumix DMC-GF2 Back Panel Buttons Replacement, Back Panel Buttons: stap 10, afbeelding 2 van 2
      • Push on the back panel buttons from the frontside of the back cover.
      • There might be some adhesives holding the back panel buttons to the cover. Extra force may be necessary.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kingsley East
474 Reputatie
4 handleidingen geschreven
Baylor, Team 5-9, Williams Fall 2016 Lid van Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 29
Altijd: 1,217
