Ga door naar hoofdinhoud
Panasonic KX-TGE233 Earpiece Speaker Replacement
Wat je nodig hebt
  1. Panasonic KX-TGE233 Earpiece Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Panasonic KX-TGE233 Earpiece Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the handset over to expose the back panel, and slide the panel out to remove.
  2. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 2, afbeelding 1 van 1
    • Carefully remove the two batteries by lifting up from one end.
  3. Panasonic KX-TGE233 Earpiece Speaker Replacement, Handset Front Panel Assembly: stap 3, afbeelding 1 van 1
    • Remove the two screws behind the battery panel by using a Philips size #00 screwdriver.
  4. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 4, afbeelding 1 van 1
    • Using a spudger, open the device by starting from the bottom and working your way to the top.
    • This will require some force, so be careful not to break any of the wires inside of the device.
  5. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 5, afbeelding 1 van 1
    • Once the back has been separated from the rest of the device, carefully place it to the side. Be careful not to completely remove it, however, as there are wires connecting the back to the handset.
  6. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 6, afbeelding 1 van 1
    • Using the same screwdriver as before, remove the Philips size #00 screw holding the motherboard in place.
  7. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 7, afbeelding 1 van 1
    • With the screw removed, the front panel assembly can be separated from the rest of the device.
  8. Panasonic KX-TGE233 Earpiece Speaker Replacement, Earpiece Speaker: stap 8, afbeelding 1 van 1
    • Now that the unit is separated from the front panel, proceed to remove the piece with the screen and buttons from the back panel.
    • Be careful not to harm the wires connecting the back speaker.
  9. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 9, afbeelding 1 van 1
    • Remove the earpiece speaker from its resting spot on the front of the device. Be careful not to remove this speaker from the device entirely before moving to the next steps.
  10. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 10, afbeelding 1 van 1
    • The device should now be flipped over, as the wires connecting the earpiece speaker make contact on the back.
  11. Panasonic KX-TGE233 Earpiece Speaker Replacement: stap 11, afbeelding 1 van 1
    • Use a soldering iron to loosen the soldering on the contact points. If heated properly, the contacts should be loose enough that the speaker can easily be removed.
    • For tips on how to solder, use the following guide: Technique: How To Solder and Desolder Connections
Conclusie
Jesse Satterwhite
682 Reputatie
5 handleidingen geschreven
IUPUI, Team 2-2, Baechle Spring 2016 Lid van IUPUI, Team 2-2, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G2
5 Leden
15 handleidingen geschreven
1Gids Commentaar
But where do you get a replacement speaker? That seems to be the impossible task!
fvasnun1 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 2,993
