Inleiding
Use this guide to remove the right function board from the front panel of the DVD player.
Wat je nodig hebt
Eject the disk tray from the DVD player before removing power supply.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Één andere persoon heeft deze handleiding voltooid.
