Ga door naar hoofdinhoud
Panasonic DVD-RV31 Player Left Control Board Replacement
Wat je nodig hebt
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: stap 1, afbeelding 1 van 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Outer Case: stap 1, afbeelding 2 van 2
      • Remove the three screws running along the back edge of case cover.
      • Remove the two screws from each side of the case cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic DVD-RV31 Player Left Control Board Replacement: stap 2, afbeelding 1 van 1
      • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: stap 3, afbeelding 1 van 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Front Panel: stap 3, afbeelding 2 van 2
      • Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: stap 4, afbeelding 1 van 2 Panasonic DVD-RV31 Player Left Control Board Replacement, Left Control Board: stap 4, afbeelding 2 van 2
      • Grip jogger dial and lift up. It should come off easily.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic DVD-RV31 Player Left Control Board Replacement: stap 5, afbeelding 1 van 3 Panasonic DVD-RV31 Player Left Control Board Replacement: stap 5, afbeelding 2 van 3 Panasonic DVD-RV31 Player Left Control Board Replacement: stap 5, afbeelding 3 van 3
      • Remove 4 mounting screws as shown.
      • Unscrew and save brass tab.
      • Push in 2 plastic retainers and lift out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Kevin
375 Reputatie
8 handleidingen geschreven
Cal Poly, Team 18-20, Garner Spring 2011 Lid van Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Leden
36 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 2,470
