Ga door naar hoofdinhoud
Panasonic DMC-FZ70 LCD Screen Replacement
Wat je nodig hebt
    1. Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement, Back Panel: stap 1, afbeelding 2 van 2
      • All screws should be removed using a Phillips #0 screwdriver.
      • Using your screwdriver, unscrew the two 5.0 mm Philips screws to the right of the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic DMC-FZ70 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement: stap 2, afbeelding 2 van 2
      • Flip the camera over to the left side of the screen and unscrew the 5mm Phillips screw found there.
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic DMC-FZ70 LCD Screen Replacement: stap 3, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement: stap 3, afbeelding 2 van 2
      • Turn the camera upside down and unscrew the three 5mm screws found on the bottom.
      Vraag FixBot
      Voeg opmerking toe
    4. Panasonic DMC-FZ70 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • On the top of the camera locate the two rails with a thin sheet of metal on the floor between them.
      • With a metal spudger, lift this sheet and push it out of the rail device to detach it from the camera.
      Vraag FixBot
      Voeg opmerking toe
    5. Panasonic DMC-FZ70 LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • Proceed to remove the four 5mm Phillips screws that you just uncovered.
      Vraag FixBot
      Voeg opmerking toe
    6. Panasonic DMC-FZ70 LCD Screen Replacement: stap 6, afbeelding 1 van 1
      • Slowly pull on both side of the camera, until both halves begin to separate from each other.
      • Do not pull too hard, as both halves are held together with ZIF connector cables.
      Vraag FixBot
      Voeg opmerking toe
    7. Panasonic DMC-FZ70 LCD Screen Replacement: stap 7, afbeelding 1 van 3 Panasonic DMC-FZ70 LCD Screen Replacement: stap 7, afbeelding 2 van 3 Panasonic DMC-FZ70 LCD Screen Replacement: stap 7, afbeelding 3 van 3
      • Using a plastic opening tool, carefully flip up the small black levers that attach the ribbon cables to the ZIF connectors on the motherboard.
      • Carefully pull the ribbon cables out of the slot once they have been released.
      • Only the two indicated connectors need to be removed to separate the two halves of the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 2 van 2
      • Unscrew the five 5mm screws on the panel that you just removed.
      Vraag FixBot
      Voeg opmerking toe
    2. Panasonic DMC-FZ70 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Panasonic DMC-FZ70 LCD Screen Replacement: stap 9, afbeelding 2 van 2
      • Remove the entire silver panel to reveal the back of the LCD screen
      Vraag FixBot
      Voeg opmerking toe
    3. Panasonic DMC-FZ70 LCD Screen Replacement: stap 10, afbeelding 1 van 1
      • Remove the LCD screen.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Alberto Rodriguez
537 Reputatie
4 handleidingen geschreven
Cal Poly, Team 21-3, Maness Winter 2017 Lid van Cal Poly, Team 21-3, Maness Winter 2017
CPSU-MANESS-W17S21G3
6 Leden
12 handleidingen geschreven
5Gids Commentaar
Where can I find the screen to replace the one that is cracked?
tim krikston - Antwoord Deel
i am not able to find the new display where-in they could ship it to INDIA
if u find any please mail me - ppavanshetty@gmail.com
Ppavan Shetty - Antwoord Deel
After replacement the camera won't work, turn on but it doesn't work.
Harold De La Matta - Antwoord Deel
After the LCD replacement my camera turn on but it doesn't work. Any ideas?
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 31
Altijd: 3,461
