Ga door naar hoofdinhoud
Palm m500 LCD Screen Replacement
Wat je nodig hebt
  1. Palm m500 LCD Screen Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Remove the stylus from the side of the PDA by sliding it upwards.
    Vraag FixBot
    Voeg opmerking toe
  2. Palm m500 LCD Screen Replacement: stap 2, afbeelding 1 van 2 Palm m500 LCD Screen Replacement: stap 2, afbeelding 2 van 2
    • Remove the 4 screws from the corners of the back panel of the device using a size T6 Torx screwdriver.
    • Place screws in a plastic bag or another safe place.
    Vraag FixBot
    Voeg opmerking toe
  3. Palm m500 LCD Screen Replacement: stap 3, afbeelding 1 van 3 Palm m500 LCD Screen Replacement: stap 3, afbeelding 2 van 3 Palm m500 LCD Screen Replacement: stap 3, afbeelding 3 van 3
    • Insert the edge of the plastic opening tool between the back panel and the black stylus holder.
    • Carefully and forcefully pry the panels apart.
    Vraag FixBot
    Voeg opmerking toe
  4. Palm m500 LCD Screen Replacement, Battery: stap 4, afbeelding 1 van 3 Palm m500 LCD Screen Replacement, Battery: stap 4, afbeelding 2 van 3 Palm m500 LCD Screen Replacement, Battery: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Use tweezers to unplug the battery cable from the motherboard socket.
    • Gently remove the battery from the motherboard using your thumb and forefinger to pull upwards.
    • The battery may be difficult to remove because of light adhesive on the back. It may require some force to pry the battery away from the motherboard with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  5. Palm m500 LCD Screen Replacement, Motherboard: stap 5, afbeelding 1 van 3 Palm m500 LCD Screen Replacement, Motherboard: stap 5, afbeelding 2 van 3 Palm m500 LCD Screen Replacement, Motherboard: stap 5, afbeelding 3 van 3
    • Use the plastic opening tool to pry the orange clamp away from the motherboard.
    • Use the plastic opening tool at the bottom of the device to pry the motherboard away from the front plate.
    • Gently and forcefully lift the motherboard away from the front plate by using your thumb and forefinger.
    Vraag FixBot
    Voeg opmerking toe
  6. Palm m500 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 2 Palm m500 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 2
    • Pull the LCD screen up from the bottom of the device using your forefinger.
    • The LCD screen will easily come away from the front panel.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Miles Johnson
624 Reputatie
4 handleidingen geschreven
Cal Poly, Team 14-9, Forte Winter 2011 Lid van Cal Poly, Team 14-9, Forte Winter 2011
CPSU-FORTE-W11S14G9
6 Leden
12 handleidingen geschreven
1Gids Commentaar
The hardest part is getting the back plate off, I throttled my plastic spudger.
dpchoung - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 34
Altijd: 2,750
