Ga door naar hoofdinhoud
Palm m105 Motherboard Replacement
Wat je nodig hebt
    1. Palm m105 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
      • Start with your intact Palm m105.
      Vraag FixBot
      Voeg opmerking toe
    2. Palm m105 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Remove protective flap by pulling directly out from the top.
      • The two clips will pop out.
      Vraag FixBot
      Voeg opmerking toe
    3. Palm m105 Motherboard Replacement: stap 3, afbeelding 1 van 1
      • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
      • The Faceplate will then easily lift off.
      Vraag FixBot
      Voeg opmerking toe
    4. Palm m105 Motherboard Replacement: stap 4, afbeelding 1 van 2 Palm m105 Motherboard Replacement: stap 4, afbeelding 2 van 2
      • Using a T5 Torx screwdriver, remove the four screws located on the back of the device turning counter clockwise.
      Vraag FixBot
      Voeg opmerking toe
    5. Palm m105 Motherboard Replacement: stap 5, afbeelding 1 van 1
      • This is what the device looks like once you have taken the screws out and opened the device.
      Vraag FixBot
      Voeg opmerking toe
    6. Palm m105 Motherboard Replacement: stap 6, afbeelding 1 van 1
      • The motherboard and screen will pop out of the back case easily.
      • Be careful when doing this step; the components are fragile.
      Vraag FixBot
      Voeg opmerking toe
    7. Palm m105 Motherboard Replacement: stap 7, afbeelding 1 van 1
      • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
      • This step needs to be done with special care because it is very fragile.
      • Once they are all three popped up the motherboard and screen will separate easily.
      Vraag FixBot
      Voeg opmerking toe
    8. Palm m105 Motherboard Replacement: stap 8, afbeelding 1 van 1
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron
22 Reputatie
1 Handleiding geschreven
UW Stout, Team 1-3, Zhou Fall 2011 Lid van UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 55
Altijd: 1,598
