Ga door naar hoofdinhoud
Palm Treo Pro Motherboard Replacement
Wat je nodig hebt
    1. Palm Treo Pro Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
      • Press down on the back of the case and slide forward to remove it.
      Vraag FixBot
      Voeg opmerking toe
    2. Palm Treo Pro Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Remove the battery by pulling up on the tab near the camera lens.
      • Insert the new battery into the open slot. Make sure the battery is oriented so that the Palm logo is in the upper-left corner opposite the camera lens.
      Vraag FixBot
      Voeg opmerking toe
    1. Palm Treo Pro Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement, Motherboard: stap 3, afbeelding 3 van 3
      • Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
      • Be careful not to misplace these screws as they are very small and will be important during reassembly.
      • If the screws are stripped a flat head screw driver may be necessary.
      Vraag FixBot
      Voeg opmerking toe
    2. Palm Treo Pro Motherboard Replacement: stap 4, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement: stap 4, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement: stap 4, afbeelding 3 van 3
      • Use a plastic opening tool to remove the small panel on the top of the phone by prying underneath the black plastic around the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Palm Treo Pro Motherboard Replacement: stap 5, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement: stap 5, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement: stap 5, afbeelding 3 van 3
      • Remove the main plastic body
      • Insert the plastic opening tool into the slot on the top (indicated by the spudger) and pry the black part off phone.
      • The bottom piece around the headphone and USB port may get caught during this step. Simply carefully maneuver the case until it is released.
      Vraag FixBot
      Voeg opmerking toe
    4. Palm Treo Pro Motherboard Replacement: stap 6, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement: stap 6, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Use the Philips Head 00 screwdriver to unscrew the 3.5mm silver screw on the right hand side of the phone.
      • Use the Philips Head 00 screwdriver to unscrew the two 3mm black screws in the upper right and lower left corners of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Palm Treo Pro Motherboard Replacement: stap 7, afbeelding 1 van 2 Palm Treo Pro Motherboard Replacement: stap 7, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Use tweezers to carefully remove the yellow piece of tape covering the two ribbon cables.
      Vraag FixBot
      Voeg opmerking toe
    6. Palm Treo Pro Motherboard Replacement: stap 8, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement: stap 8, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement: stap 8, afbeelding 3 van 3
      • There are two ribbon cables under the yellow tape.
      • Use tweezers to safely unplug the small ribbon cable first and then the large ribbon cable.
      • To remove the cables there is a small black lock that needs to be in the up position as indicated in picture two.
      Vraag FixBot
      Voeg opmerking toe
    7. Palm Treo Pro Motherboard Replacement: stap 9, afbeelding 1 van 3 Palm Treo Pro Motherboard Replacement: stap 9, afbeelding 2 van 3 Palm Treo Pro Motherboard Replacement: stap 9, afbeelding 3 van 3
      • Use a plastic opening tool to lift the motherboard up and out of the phone case
      • There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
      • It can easily be disconnected with your fingers
      • Note: During this process the mute and power buttons may fall out of the phone. Do not panic this is completely normal. Set them aside in a safe place until reassembly.
      • The motherboard has now been completely removed
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nadia Carroll
11 Reputatie
1 Handleiding geschreven
Cal Poly, Team 8-59, Johann Spring 2013 Lid van Cal Poly, Team 8-59, Johann Spring 2013
CPSU-JOHANN-S13S8G59
4 Leden
37 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 19
Altijd: 684
