Ga door naar hoofdinhoud
Palm TX Motherboard Replacement
Wat je nodig hebt
  1. Palm TX Motherboard Replacement, Back Panel: stap 1, afbeelding 1 van 2 Palm TX Motherboard Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • Orient the device so that the display faces forward.
    • Remove the stylus from the right side.
  2. Palm TX Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Turn over the device so that the back panel faces forward.
    • Use a T5 Torx screwdriver to remove the four 6.35mm corner screws.
  3. Palm TX Motherboard Replacement: stap 3, afbeelding 1 van 2 Palm TX Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Rotate the device so that the display faces forward.
    • Insert a plastic opening tool with the angled tip pointing downward into the crevice on the left side of the device.
    • Pry along the crevice to loosen the back panel.
    • Repeat this process for the right side.
  4. Palm TX Motherboard Replacement: stap 4, afbeelding 1 van 2 Palm TX Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Carefully pry the back panel to open the device.
    • Be careful not to break the wire that connects the battery pack to the motherboard.
    • When reassembling, snap the back panel back into place and then insert the top cover.
  5. Palm TX Motherboard Replacement: stap 5, afbeelding 1 van 2 Palm TX Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Use a plastic opening tool to peel the battery pack from the back panel.
    • The battery pack is glued to the back panel so removing it may require considerable effort.
  6. Palm TX Motherboard Replacement, Battery Pack: stap 6, afbeelding 1 van 2 Palm TX Motherboard Replacement, Battery Pack: stap 6, afbeelding 2 van 2
    • Use a soldering iron to disconnect the battery wires from the motherboard.
    • For soldering instructions, you can view the Soldering Guide.
  7. Palm TX Motherboard Replacement, Motherboard: stap 7, afbeelding 1 van 2 Palm TX Motherboard Replacement, Motherboard: stap 7, afbeelding 2 van 2
    • Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
  8. Palm TX Motherboard Replacement: stap 8, afbeelding 1 van 2 Palm TX Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift the mother board out of the device.
    • A weak adhesive attaches the motherboard to the device.
    • The red wire in the picture will not be attached to your device at this point.
Conclusie
Spencer Lewson
793 Reputatie
6 handleidingen geschreven
Cal Poly, Team 1-15, Amido Winter 2011 Lid van Cal Poly, Team 1-15, Amido Winter 2011
CPSU-AMIDO-W11S1G15
4 Leden
7 handleidingen geschreven
Één opmerking
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 3,430
