Inleiding
This guide shows you how to remove the PSP Go's trigger buttons.
Note: The procedure is exactly the same for the both left and right trigger buttons.
Wat je nodig hebt
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
The top cover will most likely come off during the repair, so might as well take it off now. Pull it upwards gently from its housing.
