Ga door naar hoofdinhoud
PSP 300x Trigger Buttons Replacement
Wat je nodig hebt
  1. PSP 300x Trigger Buttons Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 300x Trigger Buttons Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 300x Trigger Buttons Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. PSP 300x Trigger Buttons Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    Vraag FixBot
    Voeg opmerking toe
  3. PSP 300x Trigger Buttons Replacement: stap 3, afbeelding 1 van 2 PSP 300x Trigger Buttons Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    Vraag FixBot
    Voeg opmerking toe
  4. PSP 300x Trigger Buttons Replacement: stap 4, afbeelding 1 van 1
    • Next, unscrew the two screws located at the top of the PSP.
    Vraag FixBot
    Voeg opmerking toe
  5. PSP 300x Trigger Buttons Replacement: stap 5, afbeelding 1 van 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    Vraag FixBot
    Voeg opmerking toe
  6. PSP 300x Trigger Buttons Replacement: stap 6, afbeelding 1 van 2 PSP 300x Trigger Buttons Replacement: stap 6, afbeelding 2 van 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    Vraag FixBot
    Voeg opmerking toe
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: stap 7, afbeelding 1 van 2 PSP 300x Trigger Buttons Replacement, LCD Screen: stap 7, afbeelding 2 van 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  8. PSP 300x Trigger Buttons Replacement: stap 8, afbeelding 1 van 3 PSP 300x Trigger Buttons Replacement: stap 8, afbeelding 2 van 3 PSP 300x Trigger Buttons Replacement: stap 8, afbeelding 3 van 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Vraag FixBot
    Voeg opmerking toe
  9. PSP 300x Trigger Buttons Replacement: stap 9, afbeelding 1 van 2 PSP 300x Trigger Buttons Replacement: stap 9, afbeelding 2 van 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    Vraag FixBot
    Voeg opmerking toe
  10. PSP 300x Trigger Buttons Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    Vraag FixBot
    Voeg opmerking toe
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: stap 11, afbeelding 1 van 1
    • Remove the screw securing 'L' trigger to the PSP.
    Vraag FixBot
    Voeg opmerking toe
  12. PSP 300x Trigger Buttons Replacement: stap 12, afbeelding 1 van 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
    Vraag FixBot
    Voeg opmerking toe
  13. PSP 300x Trigger Buttons Replacement: stap 13, afbeelding 1 van 1
    • Remove the 'L' trigger from the PSP.
    Vraag FixBot
    Voeg opmerking toe
  14. PSP 300x Trigger Buttons Replacement: stap 14, afbeelding 1 van 1
    • Remove the screw securing the 'R' trigger.
    Vraag FixBot
    Voeg opmerking toe
  15. PSP 300x Trigger Buttons Replacement: stap 15, afbeelding 1 van 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
    Vraag FixBot
    Voeg opmerking toe
  16. PSP 300x Trigger Buttons Replacement: stap 16, afbeelding 1 van 1
    • Remove the 'R' trigger from the PSP.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
11 andere personen hebben deze handleiding voltooid.
cmcevill
541 Reputatie
1 Handleiding geschreven
Cal Poly, Team 19-2, Maness Fall 2009 Lid van Cal Poly, Team 19-2, Maness Fall 2009
CPSU-MANESS-F09S19G2
3 Leden
13 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 50
Afgelopen 30 dagen: 235
Altijd: 24,560
