Ga door naar hoofdinhoud
PSP 300x Power Board Replacement
Wat je nodig hebt
  1. PSP 300x Power Board Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 300x Power Board Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 300x Power Board Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  2. PSP 300x Power Board Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    Vraag FixBot
    Voeg opmerking toe
  3. PSP 300x Power Board Replacement: stap 3, afbeelding 1 van 2 PSP 300x Power Board Replacement: stap 3, afbeelding 2 van 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    Vraag FixBot
    Voeg opmerking toe
  4. PSP 300x Power Board Replacement: stap 4, afbeelding 1 van 1
    • Next, unscrew the two screws located at the top of the PSP.
    Vraag FixBot
    Voeg opmerking toe
  5. PSP 300x Power Board Replacement: stap 5, afbeelding 1 van 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    Vraag FixBot
    Voeg opmerking toe
  6. PSP 300x Power Board Replacement: stap 6, afbeelding 1 van 2 PSP 300x Power Board Replacement: stap 6, afbeelding 2 van 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    Vraag FixBot
    Voeg opmerking toe
  7. PSP 300x Power Board Replacement, LCD Screen: stap 7, afbeelding 1 van 2 PSP 300x Power Board Replacement, LCD Screen: stap 7, afbeelding 2 van 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  8. PSP 300x Power Board Replacement: stap 8, afbeelding 1 van 3 PSP 300x Power Board Replacement: stap 8, afbeelding 2 van 3 PSP 300x Power Board Replacement: stap 8, afbeelding 3 van 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Vraag FixBot
    Voeg opmerking toe
  9. PSP 300x Power Board Replacement: stap 9, afbeelding 1 van 2 PSP 300x Power Board Replacement: stap 9, afbeelding 2 van 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    Vraag FixBot
    Voeg opmerking toe
  10. PSP 300x Power Board Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    Vraag FixBot
    Voeg opmerking toe
  11. PSP 300x Power Board Replacement, Power Board: stap 11, afbeelding 1 van 1
    • Using a spudger, lift up the lock and remove the ribbon cable from the motherboard
    Vraag FixBot
    Voeg opmerking toe
  12. PSP 300x Power Board Replacement: stap 12, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the screw located on the power switch board.
    Vraag FixBot
    Voeg opmerking toe
  13. PSP 300x Power Board Replacement: stap 13, afbeelding 1 van 1
    • Lift up and remove the power-switch board.
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
7 andere personen hebben deze handleiding voltooid.
mbnewsom
3.502 Reputatie
11 handleidingen geschreven
1Gids Commentaar
for power board you can skip 7-10 steps ,1 to 6 is remove front case , real work start at step 11 ,between those was taking apart sreen, but not need for power board replacement.
javi - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 207
Altijd: 24,149
