Ga door naar hoofdinhoud
PSP 2000 Logic Board Replacement
Wat je nodig hebt
  1. PSP 2000 Logic Board Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 2000 Logic Board Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 2000 Logic Board Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    Vraag FixBot
    Voeg opmerking toe
  2. PSP 2000 Logic Board Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    Vraag FixBot
    Voeg opmerking toe
  3. PSP 2000 Logic Board Replacement: stap 3, afbeelding 1 van 2 PSP 2000 Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    Vraag FixBot
    Voeg opmerking toe
  4. PSP 2000 Logic Board Replacement: stap 4, afbeelding 1 van 2 PSP 2000 Logic Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Vraag FixBot
    Voeg opmerking toe
  5. PSP 2000 Logic Board Replacement: stap 5, afbeelding 1 van 2 PSP 2000 Logic Board Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    Vraag FixBot
    Voeg opmerking toe
  6. PSP 2000 Logic Board Replacement, Display: stap 6, afbeelding 1 van 3 PSP 2000 Logic Board Replacement, Display: stap 6, afbeelding 2 van 3 PSP 2000 Logic Board Replacement, Display: stap 6, afbeelding 3 van 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    Vraag FixBot
    Voeg opmerking toe
  7. PSP 2000 Logic Board Replacement: stap 7, afbeelding 1 van 3 PSP 2000 Logic Board Replacement: stap 7, afbeelding 2 van 3 PSP 2000 Logic Board Replacement: stap 7, afbeelding 3 van 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    Vraag FixBot
    Voeg opmerking toe
  8. PSP 2000 Logic Board Replacement,  Memory Stick Slot: stap 8, afbeelding 1 van 3 PSP 2000 Logic Board Replacement,  Memory Stick Slot: stap 8, afbeelding 2 van 3 PSP 2000 Logic Board Replacement,  Memory Stick Slot: stap 8, afbeelding 3 van 3
    • Remove two 4.5 mm Phillips screws from the left-hand side of the PSP.
    • Slide off the left trigger along with the plastic bracket underneath.
    • Carefully pry off left trigger button using opening tools.
    • The button is adhered to the body. It can be re-adhered with hot glue after being pried-up, if necessary.
    Vraag FixBot
    Voeg opmerking toe
  9. PSP 2000 Logic Board Replacement: stap 9, afbeelding 1 van 2 PSP 2000 Logic Board Replacement: stap 9, afbeelding 2 van 2
    • Use an opening tool to lift up the brown tab on the connector and remove the cable horizontally.
    • Gently remove the memory card slot by pulling it straight out.
    Vraag FixBot
    Voeg opmerking toe
  10. PSP 2000 Logic Board Replacement, Speaker: stap 10, afbeelding 1 van 2 PSP 2000 Logic Board Replacement, Speaker: stap 10, afbeelding 2 van 2
    • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
    • Be careful not to puncture the speaker in the process.
    • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
    Vraag FixBot
    Voeg opmerking toe
  11. PSP 2000 Logic Board Replacement, Logic Board: stap 11, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Remove the following four connections:
    • Two ribbon cables -- flip up latch and remove horizontally.
    • One wire clamp -- use an opening tool to pry it up vertically.
    • One wiring harness -- use your fingers, a PSP opening tool, or tweezers to disconnect the connector horizontally.
    • The ribbon cable near the wire clamp has a brown tab that should be lifted using an opening tool prior to removal. Be careful to not damage the ribbon or connector.
    Vraag FixBot
    Voeg opmerking toe
  12. PSP 2000 Logic Board Replacement: stap 12, afbeelding 1 van 2 PSP 2000 Logic Board Replacement: stap 12, afbeelding 2 van 2
    • Remove metal shields by gently lifting them with an opening tool.
    Vraag FixBot
    Voeg opmerking toe
  13. PSP 2000 Logic Board Replacement: stap 13, afbeelding 1 van 3 PSP 2000 Logic Board Replacement: stap 13, afbeelding 2 van 3 PSP 2000 Logic Board Replacement: stap 13, afbeelding 3 van 3
    • Double-check to make sure that all connections to the board are unplugged in order to avoid damage to your PSP.
    • Using an opening tool, delicately raise the logic board from its base.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
33 andere personen hebben deze handleiding voltooid.
espinks
3.869 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-3, Maness Fall 2009 Lid van Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Leden
48 handleidingen geschreven
5Gids Commentaar
How do I know whether my Logic Board is functioning properly or not?
Alvin Wijaya - Antwoord Deel
how can I change that little refill on the motherboard
Dmytro Yantsur - Antwoord Deel
how-do-i-repair-the-screen-conntors
james - Antwoord Deel
My psp is not turning on when battery is inserted even when plugged to electricity...and again if the battery is inserted to it the charging light turns on..Pls help m
Farotide David - Antwoord Deel
What do you call the connector that joins lcd to the board small one 4pin?
Shi Ace - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 118
Afgelopen 30 dagen: 581
Altijd: 60,881
