Ga door naar hoofdinhoud
PSP 2000 Display Replacement
Wat je nodig hebt
  1. PSP 2000 Display Replacement, Battery: stap 1, afbeelding 1 van 3 PSP 2000 Display Replacement, Battery: stap 1, afbeelding 2 van 3 PSP 2000 Display Replacement, Battery: stap 1, afbeelding 3 van 3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
    Vraag FixBot
    Voeg opmerking toe
  2. PSP 2000 Display Replacement, Front Casing: stap 2, afbeelding 1 van 1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
    Vraag FixBot
    Voeg opmerking toe
  3. PSP 2000 Display Replacement: stap 3, afbeelding 1 van 2 PSP 2000 Display Replacement: stap 3, afbeelding 2 van 2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    Vraag FixBot
    Voeg opmerking toe
  4. PSP 2000 Display Replacement: stap 4, afbeelding 1 van 2 PSP 2000 Display Replacement: stap 4, afbeelding 2 van 2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Vraag FixBot
    Voeg opmerking toe
  5. PSP 2000 Display Replacement: stap 5, afbeelding 1 van 2 PSP 2000 Display Replacement: stap 5, afbeelding 2 van 2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
    Vraag FixBot
    Voeg opmerking toe
  6. PSP 2000 Display Replacement, Display: stap 6, afbeelding 1 van 3 PSP 2000 Display Replacement, Display: stap 6, afbeelding 2 van 3 PSP 2000 Display Replacement, Display: stap 6, afbeelding 3 van 3
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
    Vraag FixBot
    Voeg opmerking toe
  7. PSP 2000 Display Replacement: stap 7, afbeelding 1 van 3 PSP 2000 Display Replacement: stap 7, afbeelding 2 van 3 PSP 2000 Display Replacement: stap 7, afbeelding 3 van 3
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
67 andere personen hebben deze handleiding voltooid.
espinks
3.869 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-3, Maness Fall 2009 Lid van Cal Poly, Team 6-3, Maness Fall 2009
CPSU-MANESS-F09S6G3
5 Leden
48 handleidingen geschreven
6Gids Commentaar
That does’t seem that hard. Is this tutorial working with the PSP2004?
Jack Galinski - Antwoord Deel
Yes it is, just did it :)
Billy - Antwoord Deel
Thanks for the great tut just fixed a trash find psp with a cracked lcd.
myhero667 - Antwoord Deel
Parfait tutoriel pour remplacer mon écran de PSP 2004. Un grand merci
Ramius59 - Antwoord Deel
I was wondering why after replacing the screen that the new one only shows a blank black screen. The backlight turns on and it plays the boot up sequence and you can play around on the Home Screen, but you just cant see what you’re doing on the screen. Everything seems connected right. Any suggestions??
Dylan Thomas - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 16
Afgelopen 7 dagen: 149
Afgelopen 30 dagen: 850
Altijd: 85,245
