Ga door naar hoofdinhoud
PSP 1000 Front Casing Replacement
Wat je nodig hebt
  1. PSP 1000 Front Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: stap 2, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
    You are dumbbb... BRO YOUR DUMB BC U DIDNT HAVE TO USE A TOOL TO OPEN THE DOOR. USE YOUR FINGER""
    Paulo Moments - Antwoord
    The battery door can be damaged dont use a tool
    That also happend to me it got destroyed by screwdriver
  3. PSP 1000 Front Casing Replacement: stap 3, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, remove the battery upwards from the system as shown.
    The use of the opening tool is completely unnecessary. There is a finger actuated opening latch button that says “PUSH” on it. Simply press down with your thumb then slide your thumb down and away, dragining the battery door with it. It will then come off. Assuming the system still has its original plastics, they may have become brittle enough that the opening tool could damage the release button or the plastic cover.
    Franklin Allen - Antwoord
  4. PSP 1000 Front Casing Replacement, Front Casing: stap 4, afbeelding 1 van 2 PSP 1000 Front Casing Replacement, Front Casing: stap 4, afbeelding 2 van 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
    Much luck to you if you have a tiny, metal screwdriver like I did, the screws might be stuck in there and may require some force.
    Squib - Antwoord
    you need to peel back the warranty sticker in order to access both the lower left and lower left screws
    Frederick zzstu Geib - Antwoord
    This is a bit misleading, you should only remove the two black screws in the battery compartment. The silver ones can stay.
    Damian Cartwright - Antwoord
    The two left hand screws won’t come out of mine
    XULF - Antwoord
    iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot.
    Fliggle_Slaps - Antwoord
    Can't edit previous comment so here's a new one:
    Standard or older iFixit screwdriver bits aren't thin enough to reach the two screws on the right near the memory stick slot. You'll need precision bits that have longer tips to reach these deep screws.
  5. PSP 1000 Front Casing Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: stap 6, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 6, afbeelding 2 van 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
Conclusie
33 andere personen hebben deze handleiding voltooid.
Henry Lee
794 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-6, Forte Winter 2010 Lid van Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Leden
28 handleidingen geschreven
3 opmerkingen
Thank you! Awesome help!
Jay Vee - Antwoord
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Antwoord
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 9
Afgelopen 7 dagen: 90
Afgelopen 30 dagen: 348
Altijd: 40,637
