Ga door naar hoofdinhoud
PSP 1000 Front Casing Replacement
Wat je nodig hebt
  1. PSP 1000 Front Casing Replacement, Battery: stap 1, afbeelding 1 van 1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Front Casing Replacement: stap 2, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 2, afbeelding 2 van 2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Front Casing Replacement: stap 3, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 3, afbeelding 2 van 2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Front Casing Replacement, Front Casing: stap 4, afbeelding 1 van 2 PSP 1000 Front Casing Replacement, Front Casing: stap 4, afbeelding 2 van 2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Front Casing Replacement: stap 5, afbeelding 1 van 1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Front Casing Replacement: stap 6, afbeelding 1 van 2 PSP 1000 Front Casing Replacement: stap 6, afbeelding 2 van 2
    • Gently separate the outer plastic casing from the rest of the system as shown.
Conclusie
32 andere personen hebben deze handleiding voltooid.
Henry Lee
752 Reputatie
4 handleidingen geschreven
Cal Poly, Team 5-6, Forte Winter 2010 Lid van Cal Poly, Team 5-6, Forte Winter 2010
CPSU-FORTE-W10S5G6
5 Leden
19 handleidingen geschreven
3 opmerkingen
Thank you! Awesome help!
Jay Vee - Antwoord
My psp is updating then psp is fallen down and battery comeout so please help me please thank you
Bye
National Nazeer - Antwoord
i also made a video on this for anyone who needs to do it that way.
https://www.youtube.com/watch?v=EIAaJyIx...
DAS Repair - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 89
Afgelopen 30 dagen: 332
Altijd: 36,801
