Ga door naar hoofdinhoud
Overclocking your eMac
Wat je nodig hebt
  1. Overclocking your eMac, Door Removal: stap 1, afbeelding 1 van 3 Overclocking your eMac, Door Removal: stap 1, afbeelding 2 van 3 Overclocking your eMac, Door Removal: stap 1, afbeelding 3 van 3
    • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
    • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
    • Remove the single phillips #2 screw on the RAM door, and remove the door
    • The screw is captive in the door, so don't worry about losing it.
    Vraag FixBot
    Voeg opmerking toe
  2. Overclocking your eMac, Bottom Screw Removal: stap 2, afbeelding 1 van 1
    • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
    • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
    • On the bottom side of the eMac, remove the following screws:
    • A single 2.5mm hex screw
    • Two #2 phillips screws
    Vraag FixBot
    Voeg opmerking toe
  3. Overclocking your eMac, Top and Side Screws: stap 3, afbeelding 1 van 3 Overclocking your eMac, Top and Side Screws: stap 3, afbeelding 2 van 3 Overclocking your eMac, Top and Side Screws: stap 3, afbeelding 3 van 3
    • Remove two 2.5mm hex screws from each of the other sides of the computer.
    Vraag FixBot
    Voeg opmerking toe
  4. Overclocking your eMac, Power Button Cable: stap 4, afbeelding 1 van 2 Overclocking your eMac, Power Button Cable: stap 4, afbeelding 2 van 2
    • Now, the shell can almost be separated from the computer.
    • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
    • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
    Vraag FixBot
    Voeg opmerking toe
  5. Overclocking your eMac, Shell Removal: stap 5, afbeelding 1 van 1
    • Now the entire shell can be removed from the computer.
    Vraag FixBot
    Voeg opmerking toe
  6. Overclocking your eMac, Panel Removal: stap 6, afbeelding 1 van 3 Overclocking your eMac, Panel Removal: stap 6, afbeelding 2 van 3 Overclocking your eMac, Panel Removal: stap 6, afbeelding 3 van 3
    • The motherboard access panel is held on by 4 phillips #2 screws.
    • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
    Vraag FixBot
    Voeg opmerking toe
  7. Overclocking your eMac, Cables: stap 7, afbeelding 1 van 3 Overclocking your eMac, Cables: stap 7, afbeelding 2 van 3 Overclocking your eMac, Cables: stap 7, afbeelding 3 van 3
    • To remove the fan assembly, several cables must be disconnected first:
    • 3-pin fan cable
    • Ground wire, requires phillips #2 screwdriver
    • 2-pin AC cable to power supply
    Vraag FixBot
    Voeg opmerking toe
  8. Overclocking your eMac, Screws: stap 8, afbeelding 1 van 2 Overclocking your eMac, Screws: stap 8, afbeelding 2 van 2
    • Now remove the following screws securing the fan assembly:
    • 3x coarse thread phillips #2
    • 1x machine thread phillips #2
    Vraag FixBot
    Voeg opmerking toe
  9. Overclocking your eMac: stap 9, afbeelding 1 van 1
    • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
    Vraag FixBot
    Voeg opmerking toe
  10. Overclocking your eMac, Assembly Removal: stap 10, afbeelding 1 van 2 Overclocking your eMac, Assembly Removal: stap 10, afbeelding 2 van 2
    • You should now be able to remove the fan assembly.
    • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
    Vraag FixBot
    Voeg opmerking toe
  11. Overclocking your eMac, Bottom Connectors: stap 11, afbeelding 1 van 1
    • There are four connectors at the bottom of the motherboard that must be removed.
    Vraag FixBot
    Voeg opmerking toe
  12. Overclocking your eMac, Display Connector: stap 12, afbeelding 1 van 3 Overclocking your eMac, Display Connector: stap 12, afbeelding 2 van 3 Overclocking your eMac, Display Connector: stap 12, afbeelding 3 van 3
    • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
    Vraag FixBot
    Voeg opmerking toe
  13. Overclocking your eMac, Power Button Cable: stap 13, afbeelding 1 van 1
    • The power button cable may be tucked in the casing, you will need to un-tuck it.
    Vraag FixBot
    Voeg opmerking toe
  14. Overclocking your eMac, Screws: stap 14, afbeelding 1 van 3 Overclocking your eMac, Screws: stap 14, afbeelding 2 van 3 Overclocking your eMac, Screws: stap 14, afbeelding 3 van 3
    • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
    • 2 large ones near the drive bay door.
    • 7 smaller ones scattered around
    Vraag FixBot
    Voeg opmerking toe
  15. Overclocking your eMac, Screws (Continued): stap 15, afbeelding 1 van 2 Overclocking your eMac, Screws (Continued): stap 15, afbeelding 2 van 2
    • More of the screw locations from the previous step
    Vraag FixBot
    Voeg opmerking toe
  16. Overclocking your eMac, Motherboard Assembly: stap 16, afbeelding 1 van 1
    • The motherboard assembly should now come free.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Emmanouil Georgopoulos
115 Reputatie
1 Handleiding geschreven
2Gids Commentaar
i am searching a POWER BUTTON for my old eMac(2004)
somebody can help me?
my email:cabanel.robert@orange.fr
thank you!
capitaine NEMO - Antwoord Deel
Where is Overclocking ?)
Pavel - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 61
Altijd: 2,823
