Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
Using a flat-head screwdriver, pry the power cord from the base of the toaster.
Using a flat-head screwdriver, pry the white wire from the base.
Locate the circuit board at the front of the toaster where the power cord and white wire meet.
Pull the circuit board up and out to free the circuit board from the body of the toaster.
Desolder the power cord from the circuit board at the locations show in the diagram.
Unscrew the two 1.5cm Phillips-head screws at the back of the toaster that are holding the power cord in place to remove the retaining clip.
Remove the plastic retaining clip that is holding the cord in place.
