Ga door naar hoofdinhoud
Oregon Scientific RM318PA Power Switch Replacement
Wat je nodig hebt
    1. Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: stap 1, afbeelding 1 van 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: stap 1, afbeelding 2 van 3 Oregon Scientific RM318PA Power Switch Replacement, Battery Compartment Cover: stap 1, afbeelding 3 van 3
      • Hold clock so that the clock face is facing away from you.
      • Using your thumbs, push up on the battery cover.
      • Once battery cover is removed, pull down on AC Adapter Jack.
      Vraag FixBot
      Voeg opmerking toe
    2. Oregon Scientific RM318PA Power Switch Replacement, Batteries: stap 2, afbeelding 1 van 1
      • Use one hand to stabilize the clock.
      • Using your other hand, push batteries toward spring and pull out at an angle.
      Vraag FixBot
      Voeg opmerking toe
    3. Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: stap 3, afbeelding 1 van 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: stap 3, afbeelding 2 van 3 Oregon Scientific RM318PA Power Switch Replacement, Back of Projection Clock: stap 3, afbeelding 3 van 3
      • Use a Plastic Opening Tool to pry off the silver casing on the back.
      • Pry at the top of device.
      • Once the back is open at the top, pry at the side of the device closest to the battery compartment.
      • On/Off switch should come off with casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: stap 4, afbeelding 1 van 2 Oregon Scientific RM318PA Power Switch Replacement, On/Off Switch: stap 4, afbeelding 2 van 2
      • Insert switch into slot as shown in picture. Push in until you hear a "click."
      • Replace the back of the clock by pressing cover back into place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Maxine Holden
500 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 32
Altijd: 1,874
