Ga door naar hoofdinhoud
Oral-B White Pro 1000 Motherboard Replacement
Wat je nodig hebt
  1. Oral-B White Pro 1000 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Remove the brush head by pulling the top away from the base.
  2. Oral-B White Pro 1000 Motherboard Replacement: stap 2, afbeelding 1 van 3 Oral-B White Pro 1000 Motherboard Replacement: stap 2, afbeelding 2 van 3 Oral-B White Pro 1000 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Pry open the end cap from the toothbrush body.
    • Remove the spring.
  3. Oral-B White Pro 1000 Motherboard Replacement: stap 3, afbeelding 1 van 2 Oral-B White Pro 1000 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Apply pressure on the brush shaft to release the toothbrush internals.
    • Remove the internals through the bottom of the toothbrush body.
  4. Oral-B White Pro 1000 Motherboard Replacement: stap 4, afbeelding 1 van 2 Oral-B White Pro 1000 Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use flat head screwdriver to remove power button pressure plate.
  5. Oral-B White Pro 1000 Motherboard Replacement: stap 5, afbeelding 1 van 3 Oral-B White Pro 1000 Motherboard Replacement: stap 5, afbeelding 2 van 3 Oral-B White Pro 1000 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Desolder the coil wire from the motherboard.
    • Check out this helpful guide for some soldering and desoldering tips.
    • Squeeze and remove coil from motherboard.
  6. Oral-B White Pro 1000 Motherboard Replacement: stap 6, afbeelding 1 van 2 Oral-B White Pro 1000 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Desolder the motor from motherboard.
    • Remove motherboard and battery from body of toothbrush internals.
  7. Oral-B White Pro 1000 Motherboard Replacement: stap 7, afbeelding 1 van 2 Oral-B White Pro 1000 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Desolder the battery connections from the motherboard.
    • Remove motherboard from battery holder.
Conclusie
Reattach new motherboard and reassemble your device following instructions in reverse order. Solder appropriate connections during reassembly.
Hannah Parker
203 Reputatie
1 Handleiding geschreven
IUPUI, Team S5-G4, Baechle Fall 2017 Lid van IUPUI, Team S5-G4, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G4
3 Leden
6 handleidingen geschreven
Één opmerking
Motor are brushless?
joseferreira_ms - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 54
Altijd: 2,655
