Ga door naar hoofdinhoud
Optoma HD20 Focal Lens Replacement
Wat je nodig hebt
  1. Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: stap 1, afbeelding 1 van 2 Optoma HD20 Focal Lens Replacement, Disassembling Optoma HD20 Cover: stap 1, afbeelding 2 van 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Vraag FixBot
    Voeg opmerking toe
  2. Optoma HD20 Focal Lens Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Optoma HD20 Focal Lens Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Vraag FixBot
    Voeg opmerking toe
  4. Optoma HD20 Focal Lens Replacement: stap 4, afbeelding 1 van 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Vraag FixBot
    Voeg opmerking toe
  5. Optoma HD20 Focal Lens Replacement, Focal Lens: stap 5, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the small black 2 mm screw on the side of the focal lens.
    Vraag FixBot
    Voeg opmerking toe
  6. Optoma HD20 Focal Lens Replacement: stap 6, afbeelding 1 van 1
    • Remove the focal lens by twisting it clockwise until it comes off.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Trever
1.282 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-23, Maness Winter 2015 Lid van Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 50
Altijd: 4,833
