Inleiding
Use this guide to remove the fan from your Optoma HD20.
Wat je nodig hebt
Twist the focal cap clockwise until it is fully extended.
Remove the focal cap by pulling it straight out.
6 andere personen hebben deze handleiding voltooid.
6Gids Commentaar
Very nice set of instructions! Excellent images and identification of items to remove. Thank you!
I am trying to determine if the fan works or not. Should the fan come on when there is no bulb in the projector? I removed the bulb when it burned up and I am not sure whether it was due to a failed fan or simply the bulb.
Amazing! Thank you!!! Took a bit of effort to get the fan but in the end it worked like a charm!! Thank you for saving money!!!!
