Ga door naar hoofdinhoud
Optoma HD20 Air Filter Replacement
Wat je nodig hebt
  1. Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: stap 1, afbeelding 1 van 2 Optoma HD20 Air Filter Replacement, Disassembling Optoma HD20 Cover: stap 1, afbeelding 2 van 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
    Vraag FixBot
    Voeg opmerking toe
  2. Optoma HD20 Air Filter Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
    Vraag FixBot
    Voeg opmerking toe
  3. Optoma HD20 Air Filter Replacement: stap 3, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
    Vraag FixBot
    Voeg opmerking toe
  4. Optoma HD20 Air Filter Replacement: stap 4, afbeelding 1 van 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
    Vraag FixBot
    Voeg opmerking toe
  5. Optoma HD20 Air Filter Replacement, Air Filter: stap 5, afbeelding 1 van 3 Optoma HD20 Air Filter Replacement, Air Filter: stap 5, afbeelding 2 van 3 Optoma HD20 Air Filter Replacement, Air Filter: stap 5, afbeelding 3 van 3
    • Carefully peel off each air filter from the device
    • Pull up on the air filter to remove it.
    Vraag FixBot
    Voeg opmerking toe
  6. Optoma HD20 Air Filter Replacement: stap 6, afbeelding 1 van 1
    • Remove the air filter from the device.
    • Try not to deposit dirt from the air filter into the inside of the device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Trever
1.282 Reputatie
6 handleidingen geschreven
Cal Poly, Team 21-23, Maness Winter 2015 Lid van Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 Leden
12 handleidingen geschreven
1Gids Commentaar
There were no filters where the photos indicate.
Michael - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 66
Altijd: 13,582
