Inleiding
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Wat je nodig hebt
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm Torx security screws on the back of the PS4.
Use the tip of a spudger to disconnect the antenna cable from the motherboard.
Remove the four screws securing the optical drive.
Three 9.7 mm Torx screws
One 6.2 mm Phillips screw
