Ga door naar hoofdinhoud
Oppo X9000 Volume Button Replacement
Wat je nodig hebt
  1. Oppo X9000 Volume Button Replacement, Removing the Back Cover: stap 1, afbeelding 1 van 2 Oppo X9000 Volume Button Replacement, Removing the Back Cover: stap 1, afbeelding 2 van 2
    • Turn the phone over so that you are facing the back side of the phone.
    • With your fingers, pry the back cover up starting from the top of the phone near the headphone jack and camera.
    • Completely remove the back cover by moving down the sides and bottom with your fingers.
    Vraag FixBot
    Voeg opmerking toe
  2. Oppo X9000 Volume Button Replacement, Removing the Battery: stap 2, afbeelding 1 van 1
    • With your finger, remove the battery from the phone by gently lifting the top-right corner nearest to the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Oppo X9000 Volume Button Replacement, Remove the Back Panel Screws: stap 3, afbeelding 1 van 2 Oppo X9000 Volume Button Replacement, Remove the Back Panel Screws: stap 3, afbeelding 2 van 2
    • Remove the twelve exposed 3.6 mm Phillips screws on the rear of the phone using the 3.6 mm Phillips screwdriver.
    • Store all the screws in a safe place where you will not lose them.
    Vraag FixBot
    Voeg opmerking toe
  4. Oppo X9000 Volume Button Replacement, Remove the Rubber Stoppers: stap 4, afbeelding 1 van 2 Oppo X9000 Volume Button Replacement, Remove the Rubber Stoppers: stap 4, afbeelding 2 van 2
    • Remove the three circular rubber screw covers on the back of the phone by slipping the spudger into the border between the rubber cover and the chassis. In one motion, pry the stopper out of the hole. This can take some force.
    Vraag FixBot
    Voeg opmerking toe
  5. Oppo X9000 Volume Button Replacement, Remove the Newly Exposed Screws: stap 5, afbeelding 1 van 1
    • With the 3.6 mm Phillips screwdriver, remove the three newly exposed 3.6mm Phillips screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Oppo X9000 Volume Button Replacement, Lift off the Back Panel: stap 6, afbeelding 1 van 2 Oppo X9000 Volume Button Replacement, Lift off the Back Panel: stap 6, afbeelding 2 van 2
    • Insert the plastic opening tool underneath the chassis near the power button and pry the chassis from the phone. This should take a little force.
    Vraag FixBot
    Voeg opmerking toe
  7. Oppo X9000 Volume Button Replacement, Remove the Volme Button Bracket: stap 7, afbeelding 1 van 1
    • Use the sharp end of the spudger to pry the volume button bracket from the side of the rear case.
    Vraag FixBot
    Voeg opmerking toe
  8. Oppo X9000 Volume Button Replacement, Let the Button Fall Out: stap 8, afbeelding 1 van 1
    • Rotate the phone onto its side so that the volume button falls out with ease.
    • Make sure not to lose the volume button.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Joe Hanacek
562 Reputatie
2 handleidingen geschreven
Cal Poly, Team 4-45, Amido Fall 2014 Lid van Cal Poly, Team 4-45, Amido Fall 2014
CPSU-AMIDO-F14S4G45
5 Leden
32 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 39
Altijd: 2,141
