Ga door naar hoofdinhoud
Opening the Withings ScanWatch (Gen 1)
Wat je nodig hebt
  1. Opening the Withings ScanWatch (Gen 1), Open the Case: stap 1, afbeelding 1 van 1
    • The watch is held together by friction and a thin black gasket. There are no screws or glue.
    • Place a thin metal smartphone opening tool between the metal case and the glass/display side of the watch, not on the sensor side.
    • Work your way around the watch carefully to release the gasket.
    Vraag FixBot
    Voeg opmerking toe
  2. Opening the Withings ScanWatch (Gen 1), Disconnect the Sensor Cable: stap 2, afbeelding 1 van 1
    • Once the watch is open, you can see the movement and a small cable connecting the sensor to it.
    • The cable has an iPhone-like connector and can be released with a plastic spudger.
    • Carefully pry the connector straight up to avoid damage.
    • Do not pull on the cable. Disconnect the connector first.
    Vraag FixBot
    Voeg opmerking toe
  3. Opening the Withings ScanWatch (Gen 1), Open the Case: stap 3, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  4. Opening the Withings ScanWatch (Gen 1), Disconnect the Sensor Cable: stap 4, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
    • The battery can be replaced, but it is soldered to the board.
    • You need soldering experience and the right tools.
    • This is not a beginner step and can damage the board.
    Vraag FixBot
    Voeg opmerking toe
    • Reconnect the sensor cable.
    • Make sure the O-ring gasket sits fully in the corner of the metal ring.
    • Press the glass and ring back in with even pressure. This may take force.
    • Remove any adhesive residue and let the adhesive cure if you used any.
    • If the gasket does not sit properly, the watch will not close fully.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Hopefully the photos and the steps help. Withings does not offer much more information or support, so this guide fills in some of the gaps.
Have you found a better way to handle this repair? Share your experience in the comments so we can keep building our repair knowledge together.
Cäsh
7 Reputatie
2 handleidingen geschreven
6Gids Commentaar
Hi,
Thanks for teardown and information!
Please let me know where to buy battery from?
Albert Einstein - Antwoord Deel
It seems like these are the battery suppliers. Battery. Sadly you can’t cheaply buy from them…
Cäsh - Antwoord Deel
Where can I find the saphire glass if its broken?
krunal modi - Antwoord Deel
Also looking for a battery: where could I find it? model seems to be "FLPB302828R"
dvd - Antwoord Deel
What about if the back cover comes loose? Mine is completely loose.
MikeA - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 51
Afgelopen 30 dagen: 264
Altijd: 4,642
